03-15-2007, 07:16 PM
| | Junior Member | | Join Date: Feb 2007
| | | Major rock chips - Paint Flaw? I have a 2005 Pontiac G6. I recently went on a trip (about 180 miles each way). When I washed the car after I got home, I noticed what I thought was dirt that didn't come off all along the lip at the rear of the rear door opening. I looked closer and noticed it was rock chips. It is on both sides of the car in that specific place. There are enough chips to look almost like the paint is just coming off.
I have gotten rock chips before, but this is literally around 100 or more small chips...from one trip! Does this sound like a paint or design flaw? |
03-15-2007, 07:21 PM
|  | Senior Member | | Join Date: Apr 2006 Location: Cobb county, GA
| | | Can you take a pic, and post it for us.
__________________ Ed To achieve excellence, excellence cannot be rushed. Technique is just as important as the product used.
While my approach takes more time, the results are far superior. |
03-15-2007, 08:01 PM
| | | I will try, I only have a cell phone camera so I would have to get the lighting perfect for it to turn out. |
03-15-2007, 08:17 PM
| | | I have the same problem with the flip headlights on my Trans Am. Will Scratch X or any product get these out? I tried the most agressive pad with menzerna intensive polish and it didn't quite make a big difference. Any suggestions?
__________________ |
03-15-2007, 08:25 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | GM is actually known for thick paint and heavy clears, so it sounds like you must have gotten stuck behind a convoy or something. I once had a Nissan, and it would scar the paint if a flower tapped it. Getting it repaired under warranty was NOT something I ever want to do again. |
03-15-2007, 08:59 PM
| | It was actually at a time of day when the highway was very clear, so I was well behind any other cars. It is in a specific enough place that it couldn't be from another vehicle. I think the way the car is designed throws debris from the front tires to this exact spot. A lot of debris.
Yes, the car is pretty dirty right now. The thick line of white you see along the edge of the door jamb is the rock chips. It is like that on both sides of the car. The rest is just dirt.
03-15-2007, 09:11 PM
|  | Senior Member | | Join Date: Sep 2006 Location: New York
| | | They suck but cant do much about them maybe u can fill it with touch up then wetsand and buff... |
03-15-2007, 09:21 PM
| | | I know there isn't much I can do. However, if that is what happens after one highway trip, I can't imagine what will happen over time. I think if it is a design flaw or a paint flaw that Pontiac should do something about it. These aren't quite like the scattered rock chips that I consider to be "wear and tear". I am posting this to see if my opinion is out of line or if this is somehow a normal thing. |
03-15-2007, 09:35 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Overland Park KS
| | | Wow, that's a lot of chips for a short drive! I just repaired some "very" serious stone chips on a black BMW that has 85,000 highway miles and it didn't have that concentration of wear. (There is a thread on AutoGeek someplace...)
It appears the design of the body sends stones right to that area of the door edge.
First, if you have any warranty, I would recommend you document exactly what happened: length of trip, highway type (concrete, asphalt, etc). Get someone with a high resolution camera to take detailed pics of the area and the rest of the car (to show GM that the condition is "localized" in that area of the door edge).
If GM fixes the edge with a re-spray and blend, or if you do that on your own, I'd recommend getting some Clear Travel Bra material and custom cut the product to fit that area.
That's some serious chippin'
Toto
03-15-2007, 10:13 PM
| | | Thanks, I thought it seemed prety unusual. I am going to take it to my dealer and see what they say tomorrow. If they won't fix it I will try to contact GM directly. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
