Go Back   Auto Geek Online Auto Detailing Forum > The Water Cooler > Off-Topic
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-03-2011, 09:49 AM   #1
courtdale's Avatar
Soo, anyone good with gas generators??
Have had this generator for a few years, it's the ole stale gas, let it sit for too long story. Tried fresh gas a few times in the past, no luck. Yesterday I decided to put some real effort into it so I bought some Carb Cleaner, and a can of Sea Foam.
Disconnected the fuel line and let the last bit of bad gas drain out. Sprayed the tank, line and intake on the carb with the cleaner. Added 1.5 gallons of gas along with a few ounces of Sea Foam. Let it sit for a while and gave it a few cranks. Nothing. Tried a few more times throughout the night, no luck.
Supposedly the next step is totally taking the thing apart and cleaning the carburator thoroughly? Would like to avoid that if possible. anyone have any other tips to get this thing going?
courtdale is offline
Old 10-03-2011, 10:16 AM   #2
tuscarora dave's Avatar
Re: Soo, anyone good with gas generators??
With some small engine carburetors there will be what looks like a drain plug or a screw of sorts on the bottom of the carb. If your generator has this it is likely the main jet mixture screw or "jet needle". You could remove it and try spoofing the main jet with a very small diameter piece of wire such as a small paper clip to dislodge any varnish or rotten gasoline solids from the orifice in the jet. If your model has this mixture screw and you do remove it, you will first want to screw it inward counting the exact amount of turns that it takes to lightly bottom out or stop turning. If it turns inward 2 and 1/2 turns until it stops then this is where you will want it to be upon re insertion of the screw or "jet needle". To return it to it's original position, simply screw it all the way in until it stops then back it out 2 and 1/2 turns to ensure the proper fuel mixture.
Check this out before tearing into things too deeply. You may have to pull the spark plug out and drizzle a little gasoline into the spark plug hole then re insert the spark plug and tighten it before pull starting the engine. You may want to try this a few times as sometimes the vacuum/pressure created by the running engine will be enough to dislodge any dried gasoline solids from the jet orifice and all will be good after some amount of time of the engine running.
Hope this helps, TD
tuscarora dave is offline
Old 10-03-2011, 10:23 AM   #3
If you have already tried this or you have removed this screw or jet needle to drain the old gasoline be sure that you have not screwed the jet needle all the way in as this would prevent fuel from being metered into the engine. If you have screwed this jet needle in all the way and do not know how many turns out it was originally, 2 and 1/2 turns out is typically a good starting point. If and when the engine does start, if it is running poorly then you may need to adjust the screw in or out slightly until you achieve a smooth running condition.
Old 10-03-2011, 12:12 PM   #4
Member
modo's Avatar
as long as the motor has spark it is a fuel issue and since there was gas left in the tank / bowl of the carb i would lean more towards the later
quick easy test is to give a small squirt of ether (starting fluid) into the air cleaner and give the cord a rip. if the motor fires for a second then its a fuel issue
as dave stated you are going to have to take the carb apart and start cleaning it unfortunately. best practice with small motors like that whether they are 4 or 2 stroke is when you are finished with them and are going to let them sit you should run them completely out of fuel. drain whatever is in the tank and let the motor die after it burns what is left in the bowl.
modo is offline
Old 10-03-2011, 12:43 PM   #5
courtdale's Avatar
Well, I guess since the BMW is going to be in the body shop all week, I can make this generator project week. Not quite as attractive as working on the car, but I guess I can use the experience.
Old 10-03-2011, 01:23 PM   #6
What size (HP) and brand engine does your generator have?
Old 10-03-2011, 03:26 PM   #7
courtdale's Avatar
B&s 10hp
Old 10-03-2011, 03:35 PM   #8
SeaJay's's Avatar
As all have stated above try those steps to trouble shoot. Ensure your getting spark from the plug. You can pull the plug, connect it to the plug wire, then hold the end of the plug (ensuring your holding the rubber plug wire), to a metal ground and pull the cord. You should be able to see if there is spark.
Depending on the type of carb it has, you may have to purchase a new one. This happened to my snow blower last year. I had to rip the thing apart tried to clean the carb jet, etc and nothing worked. Ordered a new one, installed it and it cranked right over. It was my error as I didn't run all the gas out of it when I stored it for the summer.
SeaJay's is offline
Old 10-03-2011, 04:03 PM   #9
courtdale's Avatar
ok, we have life. I guess the sea foam and carb cleaner needed a little time. Cranked it when I got home from work tonight and it started up... but only for about 10 seconds. Spewed a good amount of white smoke, and then stalled. Now I can crank it, it starts, but only lasts for 1 second tops before it cuts out. Any ideas with the new response??
Old 10-03-2011, 04:28 PM   #10
TLMitchell's Avatar
Quote:
More carb cleaner. One of the jets or air holes is probably crudded up. I get the same thing every year with the carbed bike. Marinate in carb cleaner and keep starting it. Eventually the Seafoam and cleaner will get to wherever it's clogged.
TL
TLMitchell is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
How good is good enough? CieraSL Ask the Expert featuring Mike Phillips 24 07-17-2011 06:25 PM
New to Detailing-Is My Plan of Attack a Good One? Sonny_D Auto Detailing 101 34 06-08-2011 06:10 PM
Good vision in a downpour sydster Off-Topic 36 01-23-2011 03:15 PM
What is a Good Paint Cleaner? 1flyfisher Ask the Expert featuring Mike Phillips 15 05-23-2010 05:00 PM
The GG polisher is as good as the 3401? kbohip Flex Polishers 150 04-22-2010 05:36 PM
» May 2013
» Car Care Brands
