| Re: Nitrogen in tires? Ricka,
Ethanol contains aprox. 76,000 BTU/Gal and gasoline contains aprox. 115,500 BTU/Gal. E10 (10% ethanol) contains 111,550 BTU/Gal. or roughly 97% of the energy content of gasoline. Depending on the engine, computer, terrain and driving habits you can get somewhat close to your mileage with gasoline (call it 3% less) under ideal conditions.
There are some engine, computer, driver combinations however that will deliver up to 8 or 10% less mileage on E10. Some engine management systems will mis-read the amount of O2 in the exhaust stream as the engine burning in a "lean" condition and increase the amount of fuel delivered from the injectors. As you might imagine, this will decrease your fuel economy.
The bright side to this is that ethanol has an octane rating of +/- 110 which does help the performance of the engine. In my mis-spent youth, I ran an A Gas drag car that would outrun itself when fueled with alcohol compared to gasoline. The only difference was the jetting on the carb. The alcohol required roughly 2/3 more fuel than gas.
My business partner runs what I call toilet bowl racing (modified dirt track but they go round and round like flushing a toilet....). There are a lot of tracks they run alcohol at (better performance and the engine runs cooler) but at the longer tracks they are forced to run gasoline as the fuel cell will not hold enough alcohol to run the race without a pit stop. |
