| Shakes and rattles, depending on condition of car not much you can do, interior panels, consoles etc will eventually start to rattle as over time. If your hearing funny rubbing/squeeking sounds from the front going over bumps, check anything with bushings (axle bushings, control arms etc). Shocks as well, but especially on our trucks the bushings are the cause for noise.
You can try dynomatting or using other foam filler products that can spray inside panels if you dare so. I had an irritating rattle comming from my window in my truck. Finally tore the door apart and got inside and tracked it down to a slight space/bend in the metal that guides the windows when up/down from something.. Cut a piece from a stick felt pad and stuck it in so felt rubs the window, no more rattle. Drove me nutz on trips lol.
__________________
The real WyStang:
