Quote:
Originally Posted by Pats300zx I have been beta testing the new Ultima products for a few weeks. This line along with the new Ultimate Detailing Machine is great. I don't think anyone will be disappointed with these products. |
autodetailingsolutions has the clay block I believe you are referring to.
Advanced Technology
Just released! New innovative rubber polymer product redefines the use of clay bars. Safely and easily removes overspray, water spots, tree sap, rail dust, bugs and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. May be used with any kind of Quik Detailer type of product as a lubricant. May also be used with soap and water. Sponge retains soap and water and releases as a lubricant when gently squeezed while gliding over the surface. Unlike a clay bar this product can be cleaned by simply rinsing off the accumulated contaminates with water or in a soap bucket. Accidentally dropping it on the ground is not a problem. Just rinse the sponge pad clean and you're ready to keep using it. Easy grip sponge allows for sturdy and controlled handling, unlike clay bars where constant kneading and reshaping is required. Use up to 30 times before needing to be discarded.*Comes with easy to use instructions and tips.
In stock! Hi-Tech Body Sponge™ $27.99
Online Introductory Price
$22.95
