Of course it depends on environmental conditions but it's going to last longer than any other non dye based trim product, and it will look better and more even than any dye based product.
One of my customers told me that his Jeep fenders have lasted through two long snow storms and still look as good as the he put it on.
A user with a MINI Cooper said his has lasted 4 months in the hot Nevada heat.
I don't recommend topping it off,, you risk contaminating BW on successive applications. I'm not sure why you would since BW lasts longer than any protectant anyways. If a month or couple months isn't long enough, then just put on a little more BW. Once the fender is treated, maintenance applications will require less BW. And if you use the same applicator pad, you can actually use a saturated pad to continue application because BW never actually dries, but it's not greasy to the touch either when applied as directed.
I don't know if Optimum Opti Seal would work--does it seal silicone? I don't know many products that can bond to silicone.
Richard
Quote:
Originally Posted by budman3 How long is this going to last on the Jeep fender flares? Do you think heating the trim up before applying the product will work better? Can I top the product off with another trim protectant? When? Would Optimum Opti-seal work over Black Wow? Thanks. |
