» Official Detail Fest 2010 Information Thread!! | |  | |
11-17-2007, 02:17 PM
#11 | | Member
Proud member of the Flex nation!!!! Awesome tool. WTG AutoGeek!!!!!!!! Talk about
listening to your customers!!!
11-17-2007, 03:04 PM
#12 | | Member
First impression. Lot different than the PC. Handles alot different. I really really like the trigger mechanism allowing you to "feather" the speed of it up to whatever you have it dialed in for. The flex sounds alot different than the PC. There seems to be alot less vibration with it. I used a 6.5 LC pad (white) with Opt. Poli Seal. I didnt have any of the hopping some have experienced. From just my first try, this machine isnt playing around. I think you could do some serious correction with the Flex. I dont think I'll need another polisher for a long long time.
11-17-2007, 03:06 PM
#13 | | Member
The LC pad was a flat pad also.
ZoranC,
Got it thursday!
11-17-2007, 04:14 PM
#14 | | Senior Member
Looks like I will be adding this to my arsenal for XMAS !!!!!!!!!!!!!!!!!! Only down side to this machine is that you are locked into 1 size pad so basically you still need a pc/udm for spot/ tight areas oother than that it look promising.
__________________ Flex3401,Makita ,Flex3403,603VV and Metabo Rotarys,PC 7336,UDM,PC 7424XP, Aztec Hot Rod, CamSpray 1500A and CamSpray Foam cannon.  Ron !!!!!
11-17-2007, 04:25 PM
#15 | | Senior Member
| Quote:
Originally Posted by rwisejr Looks like I will be adding this to my arsenal for XMAS !!!!!!!!!!!!!!!!!! Only down side to this machine is that you are locked into 1 size pad so basically you still need a pc/udm for spot/ tight areas oother than that it look promising. | So a 5" B/P won't fit?
11-17-2007, 05:39 PM
#16 | | Senior Member
I want one, gotta start savin right now, does anybody know if it will work with the edge system?
11-17-2007, 06:13 PM
#17 | | Senior Member
| Quote:
Originally Posted by Excessive Detail I want one, gotta start savin right now, does anybody know if it will work with the edge system? | It has a different type of threading so rotary and PC threaded BPs and adaptors won't work ... unless Edge comes up with another new adapter for this machine ....
11-17-2007, 06:34 PM
#18 | | Member
Patrick, MikeyC is working with Edge to "prototype" an adapter for the Edge2000 system.
11-17-2007, 07:54 PM
#19 | | Senior Member
Well I can wait till the next shipment as its winter here and I won't be doing much polishing till spring anyway.If its available when i'm ready if not no big deal. I Still have my UDM,PC and rotary to tide me over .Its just another tool in bag of tricks!!!!
__________________ Flex3401,Makita ,Flex3403,603VV and Metabo Rotarys,PC 7336,UDM,PC 7424XP, Aztec Hot Rod, CamSpray 1500A and CamSpray Foam cannon.  Ron !!!!! |
11-17-2007, 08:34 PM
#20 | | Junior Member
Hey, Zoran, not sure if you still read any threads over at the other detailing sites, but there's been some negative press on the UDM lately. Sounds like it may be due to a bad batch or something, but they're randomly dying. Makes me think back to some of the e-mails we traded. Cat's out of the bag now on the Flex and not much can be done about it.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
