Re: Looking to try something new for tires.
Originally Posted by Zelfiris
How come no one mentioned Turtle Wax
Jet Black Endura-Shine Tire Coating?
Outlast PERL and Opti-bond...
Same solicitude could be said for
Infinity Shield Tire Shine!?!?
Originally Posted by spazzz
How many typical car tires will McKees coat?
4 ounces seems ike a small bottle.
Yeah, these coatings are watery and spread very well, a little does truly go a long way for sure! One thing you'll notice with these coatings is a blueish tint to the product, there's something different going on in there for sure.
You should get a solid month out of it on a DD but doing an initial coat requires the tire to be cleaned of all old dressing and grime, ofcoarse. I would do a coat, wait 15 minutes, touch the tire to make sure its dry to the touch and then add 1-2 more coats, waiting the same interval inbetween those coats. I say this because you really need to lay down a good base coat and different tires have different levels of pores.
2022 Elantra N Cyber Gray
I have found 303 Protectant to be a good dressing as it gives the look I like. I'm not a fan of glossy slick looking tires. Like many others that I have tried, I reapply ever week or two. After reading other comments here, it looks like I'll be giving McKee's a try...an application every three months sounds a lot better.
Maybe I've been in a cave eating bear, but I never knew that 303 could be used as a tire dressing.
Steve -The Titanic Was Built By Professionals But The Ark By Amateurs- "Boanerges"
•I also used 303 on tires, for many
years, because of the "look".
•Using 303 on tires has been
discussed quite often on this
forum. Here's one discussion
from ~10 years ago: http://www.autogeekonline.net/forum/...303-tires.html
I also use 303 protectant for the following:
Car and SUV - dash
SUV - running boards, mud flaps, and black exterior trim
Boat - Marine seats and cushions; fiberglass (as good as any marine sealant...and a lot easier to apply); and trim. Also spray directly on the trailer tires...great UV protection.
I didn't mention TW tire coating because its been gone off of the shelves for so long and the only way to get it is Ebay or people here who have horded it during the sales a while ago. Its really too bad they pulled the plug on it when they did, its an awesome product that was so easy to buy and use. The only downside was because of the tint it had it would stain the sides of your wheels, so it had to be wiped off right away or polished out with some good polish. I have about 4 bottles of it, so I'm good to go.
I see 303 was mentioned to use on tires, keep in mind that 303 is a rock solid brand that's always working to be one of the best
Originally Posted by Harpolith
This is what I use as well. On tires that look bad it usually takes 2 coats to get them looking good. They I just clean then. When they stop looking new I reapply. About every 3-4 months.
No idea if this stuff is better or worst than other. I like that it's mostly matte finish and gives me that new tire looking without being overly shiny. You can gloss it up a little by buffing. No idea if that lasts or not.
Going to try McKee's Tire Rejuvenator as well for comparison. DG is cheap and works - not too motivated to try too many others.
Originally Posted by FUNX650
2011 Toyota Camry SE - Magnetic Gray Metallic
I just bought aTW 2 pack for $28. It was here in 2 days with Prime.
Last Post: 12-17-2019, 05:26 PM
By Don M in forum Off-Topic
Last Post: 12-11-2016, 07:24 AM
By DogRescuer in forum Auto Detailing 101
Last Post: 06-18-2013, 07:25 AM
By ziggo99 in forum Auto Detailing 101
Last Post: 09-03-2011, 10:49 AM
By tpelfrey14 in forum Ask your detailing questions!
Last Post: 01-04-2011, 11:24 PM
