Nice car!!! See above and best of luck.Hey guys,
Fairly new here but been reading up and learning. Think I have down what I need to do but wanted to run it by and see. Ive got a 2016 Dodge Challenger. I want to give it a good detail before putting her to sleep for the winter. Here's my plans:
*Wash with two bucket method and dry with blower (No need to dry the car if you are going to clay. Wait 10 min after wash to let some of the water evaporate and then go straight to the next step
*this is where you would decontaminate
*clay bar entire car
*use GG6 DA polisher with Megs Ultimate Polish to remove the very few minor swirls marks if the swirls are minor a light cutting or polishing pad will work; make sure you do a test spot to lock-in the process
*this is where you would remove the polishing oils from MUP so that they do not interfere with the sealant. You can use an IPA solution, mineral spirits or a prep product that is sole on AGO
*seal with Wolfgang deep gloss 3.0 sealant
*apply a layer of Megs gold carnuba wax for that extra pop This is fine, but most folks don't top WGDGPS. Some actually apply a second coat after the first layer cures
I'm not too far off base am I? No Also what kind of pads should I use for the polish? Foam finish? Can I use the DA to apply sealant and wax too? Yes
Thanks for the help.
Sent from my SM-S765C using Tapatalk
