Video: How to use the Cyclo Polisher
Re: Video: How to use the Cyclo Polisher
And here's our brand new Cyclo Commercial you'll see this Sunday and Monday on "What's in Autogeek's Garage"
Cyclo Polisher Commercial [ame=http://www.youtube.com/watch?v=omBtip8cKxU&hd=1]Cyclo Polisher Commercial with Mike Phillips - YouTube[/video]
2nd episode on this Sunday! - What's in Autogeek's Garage
Uh oh ... i found the Video section of the forum
There goes a few more hours
Mike, whilst the production quality and format may have changed and improved over the last few years, there's one thing that has always been constant, and that is your ability to transfer such clear & concise information to your audience.
What is inspiring to me, is that even someone as experienced in 'The Art of Polishing Paint' such as yourself, is still motivated to seek out information then package it in an entertaining but professional format for all of us to enjoy.
Keep up the great work
I have seen 1 Cyclo here in Australia going back a few years now & am curious after watching the video of the new Version 5 featuring an adjustable speed.
Typically i have worked with a PC(non XP) after rotary buffing and always been very happy with the results.
However as time is money in business and i know very little about this machine i thought something with greater capabilities could be in order.
Mike, I noticed your hand movement was faster than i have seen on the other instructional videos.
It has me intrigued to know where the Cyclo sits amongst the PC, Flex and Rotary as far as correction capabilities?
Is the cyclo capable of taking out light sanding marks with its new adjustable fearture?
I understand there are Microfibre pads out for the PC now? - are there any for the Cyclo? (would be keen to see some literature if you have something to help explain the benefits of MF pads ... its new to me)
Given the large axis of movement the Cyclo has, does the 3000opm's compare to the higher opm's of a flex and the porter cable?
How does one tackle the more intricate panels of the vehicle? (particularly where one of the pads may not be completely on the paint surface)
I can live with the slight extra weight of the machine, i was particularly impressed with the balance of the machine in motion.
Thank you for the kind words Paul, it's greatly appreciated. For all the talk there was for years on all detailing discussion forums for more and more videos, now that there are some, for whatever reason the video threads rarely get any comments, so I for one appreciate your feedback.
Thank you.
Nothing is ever going to beat a rotary for pure brute power when it comes to removing a lot of paint fast. Their have been advances in pads and chemicals for use the the PC style tools like microfiber pads and SMAT products but still they don't compare to the speed in which you can remove paint using a rotary buffer.
Removing defects in the paint, whether swirls, scratches, water spots or sanding marks after wetsanding is just a matter of removing paint an a direct drive rotary buffer, rotating a wool pad with an aggressive compound is as fast as you can get and as fast as you want to get.
The other tools are capable of abrading paint so they are capable of doing any type of correction work but at this point in time they cannot outperform a rotary buffer when it comes to speed.
Can you wetsand a car and then use only a DA style polisher to remove sanding marks?
You bet. It just the time factor that differentiates the different types of tools.
Is the Cyclo capable of taking out light sanding marks with its new adjustable feature?
Any tool that can abrade paint, that is remove small particles of the paint in a controlled manner, (compounding and polishing), can remove sanding marks in the same way you can remove swirls and scratches.
The new variable speed feature for the Cyclo doesn't improve the tools ability nor take away from the tools ability to remove sanding marks as you're always going to be on the high speed settings for this type of work.
I understand there are Microfiber pads out for the PC now? - are there any for the Cyclo? (would be keen to see some literature if you have something to help explain the benefits of MF pads ... its new to me)
I think I've only tried microfiber pads on the Cyclo one time and I would have to revisit this pad/tool combination to refresh my memory as to the how they performed together.
I'd say yes, as long as you're using comparable pads and products.
Practice.
The tool is light weight and well balanced and virtually vibration free, it is truly unique in operation as compared to single buffing head polishers.
Plus it looks cool... I refer to it as the Buck Rogers Polisher, for some reason it just has a cool, metal retro look to it...
Thanks for the great info
Perhaps you should host seminars on how to post in forums too.
I don't think ANY forum i'm part of gives such detailed replies as yourself.
And as for Buck Rogers?
Last Post: 09-27-2012, 02:49 PM
Last Post: 04-06-2012, 09:00 AM
By SPIROS ANTONIOU in forum Cyclo Polishers
Last Post: 11-18-2010, 10:17 AM
Last Post: 06-23-2010, 06:42 PM
By Mike Phillips in forum Autogeek on Velocity Channel TV
Last Post: 05-11-2010, 12:51 PM
