» Paypal Bill Me Later | |  | |
08-04-2012, 08:02 PM
#11 | | Senior Member
| Re: The Definitive How-To Guide for Spray Waxes, Quick Detail Sprays & Waterless Washes
Hey Nick,
I don't recall seeing a more complete or well written review in quite some time. The documentation and photography clearly show how well these products work and something equally important is how easy these are to use as well.
Well done!
__________________ BobbyG - 2004 Millennium Yellow Z06 Corvette |
08-04-2012, 08:09 PM
#12 | | Senior Member
| Re: The Definitive How-To Guide for Spray Waxes, Quick Detail Sprays & Waterless Washes Quote:
Originally Posted by Bigbull2984 I was debating on getting some cause its on BOGO. But I just have so many products it would be a waste. | I saw that on bogo. I got mine as the free item on one of my purchases.
08-04-2012, 08:40 PM
#13 | | Member
Great write up! You should do more of these because you do a Great job. I also enjoyed the one you did on Collinite. Very informative, especially for new guys like me.
08-26-2012, 02:17 PM
#14 | | Senior Member
Awesome info Nick!
One question, can you comment on something like uww+ because at the same concentration it can be used as either a detail spray or rinseless wash?
08-26-2012, 07:15 PM
#15 | | Senior Member
Originally Posted by ihaveacamaro Awesome info Nick!
One question, can you comment on something like uww+ because at the same concentration it can be used as either a detail spray or rinseless wash? | It's used as a QD or waterless wash at the same concentration (1:43) - the rinseless dilution is 1 oz to 3 gallons (1:384).
__________________
Francis
08-27-2012, 10:16 AM
#16 | | Senior Member
Originally Posted by umi000 It's used as a QD or waterless wash at the same concentration (1:43) - the rinseless dilution is 1 oz to 3 gallons (1:384). | So can this QD be used to remove a film of dirt, as opposed to light dust (check Nick's post)? Because it is less diluted when using it as a QD than when using it as a bucket method cleaning.
08-27-2012, 11:47 AM
#17 | | Moderator
Originally Posted by Lawalker Great write up! You should do more of these because you do a Great job. I also enjoyed the one you did on Collinite. Very informative, especially for new guys like me. | I definitely plan on doing more and I have no problem taking requests. Quote:
One question, can you comment on something like uww+ because at the same concentration it can be used as either a detail spray or rinseless wash? | Ultima Waterless Wash Plus, like Blackfire Wet Diamond Waterless Wash, is almost considered a "hybrid" because it is packed full of gloss enhancers and protective polymers. This makes either product great for use as a waterless wash OR quick detail spray. The dilution for quick detail spray or waterless wash is the same. Quote:
Originally Posted by ihaveacamaro So can this QD be used to remove a film of dirt, as opposed to light dust (check Nick's post)? Because it is less diluted when using it as a QD than when using it as a bucket method cleaning. | Yes. See above. |
08-27-2012, 08:24 PM
#18 | | Senior Member
Originally Posted by ihaveacamaro So can this QD be used to remove a film of dirt, as opposed to light dust (check Nick's post)? Because it is less diluted when using it as a QD than when using it as a bucket method cleaning. | Within reason, yes. My usage (as a waterless wash) is a bit different from the way most people would use a QD - I mist the whole panel, then do one swipe per section of towel - one swipe only, front to back; I turn-over or fold to a fresh side immediately, so I'm not dragging grit across the paint. As you'd imagine, I use a lot of towels, but it's easier to wash towels than it is to correct paint
__________________
Francis
08-27-2012, 09:04 PM
#19 | | Senior Member
Where would the black fire rinseless wash be considered when made into a QD. Is it on par with the black fire waterless wash?
10-05-2012, 12:48 PM
#20 | | Senior Member
is the only difference between gold plush and gold plush jr the size?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » June 2013 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | » Car Care Brands | | | |
