Quote:
Originally Posted by dorkiedoode
Does the pad have to spin when you're gripping it?? I gripped it and it just vibrate on the towel. |
This is correct.
You use your fingers to grip the backing plate like I show in the video and pull the palm of face of your hand towards the face of the pad and this of course pushes the towel into the foam. Then two things happen...
1. the nap or cotton loops agitate against the foam to loose and remove any built up paint and residue gunk.
2. Because cotton absorbs, the cotton absorbs "some" of the excess liquid building up inside of the foam out of the foam.
If I lighten up the towel spin with it too. |
That's okay.
I lighten up and allow the pad to spin a little and then repeat the squishing of the towel against the pad so you're getting more and different portions of the pad clean and wicked dry.
Remember, the entire idea behind the ONE THE FLY part of the title is this...
Buffing out an ENTIRE car in one day using a PC type of polisher already takes a long time. 6-12 hours depending upon how large the car is and how good or experienced you are and of course how many machine steps you're going to do.
You WANT a way to clean your pad QUICKLY so you can get back to buffing on the paint.
You DON"T WANT a way to clean your pad that takes 10 to 15 minutes or this will add up and add to the total time it takes to buff out the car and you'll be buffing out the average car for 2 days.
nvm i think i got it now. i was expecting the pad to be all white again. |
Nope.
i guess i was expecting a little too much there lol. |
Cleaning your pad on the fly is a way to get the pad "pretty clean" not "perfectly clean". Getting your pad pretty clean is good enough to get back to work quickly and get the job done and get the job done right.
If you want perfectly clean, buy more pads and after you buff a section, remove the pad and set it aside for washing and replace it with a brand new clean pad, or a used pad that you've previously cleaned and dried.
In a perfect world, more pads is better... let your budget decide...
Hope that helps... most people make cleaning their pad on the fly harder than it has to be... it's as easy as I make it look in this video and after you get your pad pretty clean... get back to work!
How to clean your pad on the fly
The above technique works with any of the below DA Polishers,
Porter Cable DA Polisher Meguiar's DA Polisher Griot's Garage DA Polisher Shurhold DA Polisher So let’s take a look at how-to clean your pad on the fly
Cleaning your pad on the fly is where you take a terry cloth towel, usually a medium size hand towel works best, you fold it in two and then simply hold the towel against the face of the pad and then turn the polisher on and use your hand that’s holding the towel to push the towel into the foam. This will act to draw any excess liquid
out of the foam and any excess residue
off of the face of the pad.
This is me using the
Clean your Pad on the Fly Technique to clean my pad on the fly as we removed the oxidation off this
Neon.
