car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > How to Articles
» Official Detail Fest 2010 Information Thread!!
» Current Poll
What Discovery show do you watch most?
Overhaulin' - 24.34%
37 Votes
Deadliest Catch - 15.79%
24 Votes
Motor City Motors - 0%
0 Votes
Storm Chasers - 1.32%
2 Votes
Dirty Jobs - 15.79%
24 Votes
Man vs. Wild - 9.21%
14 Votes
Shark Week - 4.61%
7 Votes
Cash Cab - 1.32%
2 Votes
The Colony - 0%
0 Votes
MythBusters - 27.63%
42 Votes
Total Votes: 152
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 02-17-2009, 09:55 AM   #1
Moderator
Meghan's Avatar
Headlight Restoration
Headlight Lens Restoration Guide:
Cloudy, scratched headlight lens covers are a safety hazard as well as a blemish on your vehicle. This condition occurs because the plastic is overexposed to UV light. The cloudiness starts at the exterior surface of the lens cover and spreads inward. In intense sun climates, this damage can be apparent within a couple of years of purchasing a new car.
The good news is that this damage is very common and very fixable. This short tutorial will give you all the skills you need to restore your headlight lens covers.
Diamondite Headlight Lens/ Clear Plastic Restoration Guide
Polish headlights with the Diamondite Plastic Lens Kit to remove scratches, yellowing, and cloudiness. Enhance headlights’ performance and restore their like-new appearance with the industry’s finest headlight polishing system!
The Diamondite Clear Plastic Kit is a three step system to restore, clean, and protect your vehicle’s headlights. The system works with an electric drill or polisher using the included 4 inch pads. Remove cloudiness and oxidation caused by UV exposure, as well as light scratches and imperfections with the Diamondite Clear Plastic Kit.
Before you begin…
Tape off the area surrounding the headlights using painter’s tape. Clean off any loose debris using Diamondite Perfect Vision Glass Cleaner and a soft microfiber towel. Screw the drill adapter into the included backing plate and tighten with a wrench. Insert the adapter into your electric drill and tighten the chuck.
Step 1
Clear Plastic Enhancer
Press the included yellow cutting pad onto the backing plate. Apply Diamondite Clear Plastic Enhancer™ in an X pattern across the pad.
If you are using a drill or rotary polisher, set the maximum speed at 1800 OPM.
Work in an overlapping motion until cleaner breaks down into a clear film. Work up and down and side to side. There is no need to apply pressure to the machine.
Use the included soft microfiber towel to remove residue. Severely stained or scratched lenses may require a second treatment.
Note: Avoid polishing over the alignment dowels on the lens cover as they could tear the pad.
Step 2
Clear Plastic Restorer
Remove the yellow cutting pad and attach the included orange light cutting pad. Dispense Clear Plastic Restorer in an X pattern across the orange pad.
Work at a speed of 1800 RPM on your electric drill. Move the pad up and down and side to side for complete coverage. When the polish starts to dry, turn off the drill and slowly lift it off the headlight lens cover.
Wipe the headlight clean with the included microfiber towel. Repeat step 2 if necessary.
Step 3
Clear Plastic Liquid Armor
Mist the headlight lens with Clear Plastic Liquid Armor. Two or three pumps should be enough to cover the lens.
Use a microfiber towel to spread the sealant over the lens and flip the towel to buff dry.
Allow the sealant to cure for an hour and then apply another coat if desired.
Maintain the clear shine of your polished plastic headlights with Diamondite Plasti-Care Plastic Cleaner, Polish & Protectant. This aerosol spray cleans and shines plastic headlight covers, and it leaves a anti-static coating to keep them clean longer.
Diamondite® Clear Plastic System Kit
__________________
1-800-869-3011 ext 207
meghan@palmbeachmotoring.net
Meghan is offline
Old 02-22-2009, 09:14 PM   #2
Member
id-type-s's Avatar
Re: Headlight Restoration
would wetsanding lenses before using Diamonite improve results??
__________________
DC5
id-type-s is offline
Old 02-22-2009, 11:28 PM   #3
what would be the main difference between this and the wolfgang headlight restoration kit. Seems to me that the wolfgang version comes with an orange light cut and a black finishing so would the wolfgang version make a more clear headlight?
Speed-Dude is offline
Old 03-18-2009, 02:14 PM   #4
Member
I'm also interested in knowing the difference between the wolfgang kit and the diamondite one. From the pads it comes with I wonder if the diamondite kit is for more severely degraded headlights. Hopefully the PBMA folks can give us an answer to the differences.
bcwang is offline
Old 03-18-2009, 03:42 PM   #5
Moderator
matt@autogeek.net's Avatar
The Diamondite kit does come with more aggressive pads.
However, the pads in the Diamondite kit will NOT leave the headlights any hazier than they would in the Wolfgang kit. IMO the pads in the Diamondite kit are more effective and for more oxidized lights it gets my recommendation.
__________________
Have Detailing Questions? I'm Happy To Help!
Read The Autogeek Blog
Autogeek.net
matt@autogeek.net is offline
Old 03-18-2009, 04:36 PM   #6
Member
Do you know which of the sealants that come in each of those kits is the better one? I've got both but using the diamondite liquid armor, I question if it is adding protection. The surface does not feel slick afterwards, nor does it bead water. So I can't tell if the stuff is on there or worn off. Where the wolfgang plastik definitely leaves a slick water repellent finish.
If anyone knows how each of these plastic sealants perform compared to each other, please comment.
bcwang is offline
Old 03-18-2009, 05:33 PM   #7
Member
id-type-s's Avatar
Did you by chance wetsand before using Diamondite? If so how did it turn out?
__________________
DC5
Old 03-18-2009, 07:30 PM   #8
Member
Quote:
Actually, I only have the wolfgang kit, but also have the diamonidte liquid armor protectant but not the whole kit. No, I did not wetsand first. I actually wasn't able to get all the oxidation off, but i kind of stopped since my drill battery was dying and it was getting dark. I just finished off polishing both and sealed one headlight each with the different products.
bcwang is offline
Old 03-18-2009, 08:05 PM   #9
Member
Eurocougar's Avatar
It may not be a bad idea to throw the Wolfgang Headlight restore kit on here as well. I have used it and still see great results after 6 months of using it once!
Eurocougar is offline
Old 07-28-2009, 02:27 PM   #10
O.C.Detailing's Avatar
There's no way these kits would have worked on the headlights on my 1992 BMW 325i. The surfaces of the lenses were exteremely rough to the touch and a very deep yellow color making my Silverstar halogen headlamps look like incandescent lights. I hand-sanded using 1000 grit 3m sandpaper and Meg's Final inspection as my lubricant to wet-sand out the entire top layer of my headlamp until I got semi-smooth surface. I then followed up with 2500 grit 3m paper and the same lubricant to sand out the 1000 grit marks. I used Optimum compound to get rid of the 2500 grit sanding marks and then Optimum Polish to finish for a crystal-clear and VERY smooth and clean surface. I used Poorboy's EX-P as a sealant (2 coats, the first to cure for about 30-45 minutes) and then threw a Meg's Gold Class Carnuba Was on top to add a little more protection. Saved med at LEAST a couple hundred dollars from having to buy new headlights and they look as good as new.
O.C.Detailing is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
DIY: Headlight Lens Restoration lensch09 Auto Detailing University 10 09-16-2009 06:05 AM
Cobra headlight restoration matt@autogeek.net Show N' Shine 3 05-26-2008 08:45 PM
Headlight Restoration buster Auto Detailing University 8 03-24-2008 09:41 AM
Headlight Restoration 01vw18t Auto Detailing University 6 12-21-2007 08:47 AM
A quick headlight restoration dontsleeponit Show N' Shine 7 11-17-2007 07:05 AM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Griots Garage
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
