Results 1 to 9 of 9
    Super Member TuxedoTaurus's Avatar
    May 2014
    Tenessee
    554
    14 Camaro Engine Detail Help
    A guy in my apartment complex stopped me while dressing my tires, and asked me to detail his 14 Camaro. It has 2500 miles on it and in great shape, just very minor swirls.
    Anyway, he wants the engine compartment detailed. Is there anything out of the norm to cover up, besides the alternator and battery?
    Thanks
    Detailing is a way of life, not a hobby!
    Super Member parttimer's Avatar
    Aug 2013
    1,564
    Re: 14 Camaro Engine Detail Help
    It's probably completely covered in plastic like most engines today.
    May 2014
    Tenessee
    554
    Quote Originally Posted by parttimer View Post
    I wish it was, but there is quite a few electrical components exposed and a surprisingly roomy engine compartment.
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    This is what I do but you are in a complex so maybe cant or dont have a PW.
    I spray the entire engine down with a degreaser such as Meguiars Super Degreaser or 3D Yellow Degreaser or LA's Totally awesome all usually diluted to 10:1. Then spray it off with a power washer. I dont specifically stay completely away from the Alt/Electrical components but I do spray them MUCH less than other things.
    I usually keep the PW about 12-15 inches away from the surface Im spraying as to not force too much water into places it should be.
    I have had MUCH GOOD luck doing this for years and years. If you have a hose and nozzle then use the finest mist you have available = less water per minute.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    May 2014
    Tenessee
    554
    Quote Originally Posted by dcjredline View Post
    Thanks, I do have a Dewalt PW but only use on exterior I will use a regular hose. I do this mobile or at my in-laws place. This will be done in the owners garage(just moved back in his house).
    The engine is not really grimmey, just dusty.
    Mar 2014
    308
    I wouldn't PW an engine, I'm just saying. I know water will get into the engine compartment, I mean you DO drive in the rain. But a PW, I wound to go there!!!
    Spray it down with APC, agitate, hose it off, then blow it out... It's a new car with 2500 miles, hell just a hose off my cut it!
    GOOD LUCK!!
    Quote:
    Originally Posted by mcate
    Black isn't a color, it's a part time job.
    Aug 2013
    1,564
    Well, since you are actually going to have to clean it, I have a setting on my hose nozzle that is "mist" so I would mist the engine, spray apc, use a soft brush to loosen up the dirt, then "mist" again.
    Super Member dad07's Avatar
    Nov 2010
    Charlotte N.C.
    4,227
    With a car that new.....and that few of miles 0NR is your friend!
    Tim
    "I have done so much with so little for so long.
    Now I can do anything with nothing"
    May 2014
    Tenessee
    554
    I'm gonna try ONR first, then go traditional if it doesn't cut it.
    I just want to make sure that I don't get any surprises by missing something I need to cover.
  1. Replies: 0
    Last Post: 12-21-2019, 11:37 AM
  2. 69 camaro 1st detail
    By Frycztech in forum Auto Detailing 101
    Last Post: 05-15-2017, 03:05 PM
  3. Camaro SS detail
    By 530inv in forum Show N' Shine
    Last Post: 02-23-2013, 11:15 AM
  4. Detail: Camaro Z28
    By DRT BRD in forum Show N' Shine
    Last Post: 09-30-2012, 12:59 AM
  5. Detail: LT1 Camaro
    Last Post: 09-16-2012, 12:03 AM
