Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Flex Polishers
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-05-2012, 08:57 PM   #1
Hellspawn's Avatar
Pad sizes for flex plates 4", 5.5" and 6" ?
Ok, I have the 3401 (not used it yet), and I have the additional backing plate kit 4" and 6".
What are the proper (recommended) sizes that I should be looking at for the 4", the 5.5" and 6" plates?
Right now I have several 5.5" LC flat 7/8" pads.
When I did a test fit on the 5.5" plate of course the pad went right to the edge of the plate.
Suggestions?
Hellspawn is offline
Old 10-06-2012, 01:34 PM   #2
Re: Pad sizes for flex plates 4", 5.5" and 6" ?
I use the 4" CCS and Hydrotech pads with the 4" backing plate. I use the 5.5" CCS and 5.5" Hydrotech pads with the 5.5" backing plate. The Hydrotech pads are actually a little bigger and rounded so you can buff with the sides of the pad a bit more. I use the 6.5" CCS pads with the 5.5" BP too since my 6" BP broke. They still work just fine with the 5.5". Even though the Flex is forced rotation, the smaller pads work better IMO.
iminaquagmire is offline
Old 10-10-2012, 07:00 AM   #3
I kind of have the same question. Which pad size should I use? I ordered 6.5, but I keep reading people prefer 5" pads. Thanks in advance
DEXTERITY is offline
Old 10-10-2012, 07:18 AM   #4
Director of Training
Mike.Phillips@Autogeek's Avatar
A couple things,
While thin pads work best for DA Polishers like the PC, Griot's and Meguiar's, that's not a factor when it comes to gear driven tools.
This is just my opinion but the best pads on the market right now for the Flex 3401 are the 5" Hybrid Pads.
The face of these pads equals 5" in diameter and the design has them tapering down to the Velcro backing which is 4" and fits the 4" backing plate perfectly.
For doing major correction work, get the Blue Foamed Hybrid Pad, this thing is dang near indestructible and with a good compound will remove defects incredibly fast.
For less aggressive cutting action get either of the cutting pads and for sure get the white polishing pad and the black finishing pad.
The smaller size of the face of the pad does two things,
1. Makes the tool incredibly easy to control. You still want to practice holding the pad flat but the smaller size makes operation easy.
2. Fits the thin panels common to new cars better than larger pads.
I have an article on this and you can find it in my article list in the section dedicated to the Flex 3401, it's easy to find, just click to my article list from the link in my Signature Line which is in ALL my posts and the scroll down till you see this picture,
Flex 3401 Forced Rotation Dual Action Polisher
NEW - New 5" pads for 4" Backing Plate on Flex 3401
And here's the article showing these pads...
5" Hybrid Pads for the 4" backing plate on the Flex 3401!
These new pads are not in stock yet but you can get a glimpse of them in action below....
Live Broadcast Video - 1965 Plymouth Valiant - Extreme Makeover
***Live Broadcast Video - Extreme Makeover - 1965 Plymouth Valiant***
Here's some still pictures I took from the Valiant Extreme Makeover with Justin using them...
These pads really work well with this tool. If you don't have the 4" backing plate then ANY of the 6.5" pads from Lake Country work GREAT on it to as do the Meguiar's 7" Softbuff pads.
The larger size pads work great for tackling larger flat panels.
Mike.Phillips@Autogeek is online now
Old 10-10-2012, 07:25 AM   #5
For this 1940 Ford Couple, I purposefully set up nothing but Flex 3401 polishers with both 6.5" and 5" Hybrid pads for my students to work with and compare as they buffed out this car.
Point being, both 6.5 and the 5" Hybrid pads both work great with this too... If you have the stock or factory backing plates, then look at these pads,
6.5 CCS
6.5 Flat pads
7" Softbuff pads
6.5 Hybrids
If you have the 4" backing plate, then get the 5" Hybrids. If you want to just start with the basics, then get the orange, white and black 5" hybrids.
I loved this car for my class, everyone was excited to work on something cool that was trashed and it really came out nice...
Look through these pictures and you'll see both 6.5" 5" Hybrid Pads in use...
Wow!
Old 10-10-2012, 07:30 AM   #6
thanks for your feedback. I'm going to be working on my Ford Edge (2012 paint doesn't need much work at all) and wifes Honda Accord (2008 - paint needs some swirls, scratches removed). It will be my first time ever using a flex or anything similar to it.
I originally ordered
Lake Country 6.5 CCS Pads and a few of the hydro tech pads.
I'm debating on returning them for the 5" pads, but not sure what to do even with your previous response ?
I don't even know if I need to buy a backing plate if I keep the 6.5 pads. I assume if I go the 5" ccs pad way I need a different plate?
If the hybrid pads are available soon, then maybe I should get those? decisions, decisions. pardon my noobness.
Old 10-10-2012, 07:54 AM   #7
Quote:
The factory backing plate is 5.5" wide and works great with 6.5" pads. You can't use 5.5" pads on a 5.5" backing plate as the edge of the backing plate is dangerously close to hitting the paint. Plus the pads are too thin for this type of tool.
The Hybrid pads are available in both 6.5" and 5" sizes. You can use the 6.5" on the factory backing plate but you need to buy the Adapter Plate System to get the 4" backing plate to use with the 5" pads.
You cannot at this time get the 4" backing plate and the adapter by itself, it comes as a 3 piece kit.
Old 10-10-2012, 07:42 PM   #8
Mike, thank you very much for your time and help. I appreciate it!
Old 10-11-2012, 08:27 AM   #9
You're welcome. I love buffing out cars and helping others to buff out cars too...
By the way, we'll be using the 5" Hybrids on rotary buffers tonight on the 440 Cuda...
The Mother of all swirled-out 1970 Cuda's
Old 10-12-2012, 06:20 PM   #10
stangfreak's Avatar
mickey T's in the back. The guy does use his car. nice!!
__________________
2003 SVT COBRA
Built and prepped by Mustang Magic (home of snakebite)
Tuned by Joey at Mustang Magic
stangfreak is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
LC rotory microfiber pad 6" luv a shine Product Reviews 0 09-30-2012 08:28 PM
New 4" and 6" Backing Plates for Flex 3401 Mike.Phillips@Autogeek New Car Care Products 81 04-23-2012 03:26 PM
xc 3401 w/ 6" wool pad? sicweasel Flex Polishers 7 11-07-2011 07:23 AM
5" and 6" Backing Plates on 6.5" pads (Pictures to show safety margin) Mike.Phillips@Autogeek Hot topics and Frequently asked questions 40 08-31-2011 07:48 AM
Griot's 6" Orange Pad - Cutting or Polishing? Driven Auto Detail Wool & Foam Buffing Pads 3 03-31-2011 08:43 AM
» May 2013
» Car Care Brands
DP American Made Car Care Products
