Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Flex Polishers
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-04-2012, 09:19 AM   #1
Member
megacabcummins's Avatar
Pads for Flex questions...
I am planning on buying this kit in the next couple weeks, but I have no idea what pads to get. I will mostly be detailing my truck and the paint is in pretty decent shape (will be much better once I am done with the Dr Color Chip) so I was thinking of going with the orange/gray/red pads? Should I start with something else? Thanks for any input
megacabcummins is offline
Old 04-04-2012, 09:43 AM   #2
Director of Training
Mike.Phillips@Autogeek's Avatar
Re: Pads for Flex questions...
The Flex has enough power that it will rotate and oscillate any pad you place on the backing plate.
So the choice comes down to personal preference.
Open Cell foam will last longer, that would mean getting either 6.5" CCS or Flat Pads.
Closed Cell foam offers less tensile strength and will wear faster but many love how they perform.
The safe choice would be get one of the open cell varieties. Open cell also washed and dries better and faster than closed cell.
As for your actual pad choices, there is a great variety of levels of aggressiveness or non-aggressiveness in the CCS line as there's only 4 options in the flat pad selection.
Here's the link to our Lake Country Buffing Pad page where you can find all your pad options for the Flex 3401 including the new Hybrid and the PFW and BFW-Hybrid pads.
Lake Country Buffing Pads
Mike.Phillips@Autogeek is online now
Old 04-04-2012, 09:48 AM   #3
One thing I did that took a lot of time when I wrote my how-to book was I included a LOT of detail, for example, I went into detail on buffing pads...
Paperback
Old 04-04-2012, 10:01 AM   #4
Mike,
This is a bit confusing.
I got a set of hybrid pads after reading that they are probably a better (best?) option for the 3401. And that they were significantly better than the CCS pads for the 3401.
From your post above, it looks like you're recommending the CCS pads. Also, you're recommending open cell pads, while the hybrid pads appear to be closed cell.
What gives?
Dan.
BookemDano is offline
Old 04-04-2012, 10:04 AM   #5
FivePoint.0's Avatar
Lake Country Hybrid Pads.
__________________
Mark
'08 Nissan 350Z Enthusiast Coupe - Carbon Silver Metallic, 6MT
FivePoint.0 is online now
Old 04-04-2012, 10:14 AM   #6
Before you determine what type of pads you will need, consider diagnosing the state of your paint. Wash a panel, clay it, and see what it really looks like. If you have slight swirls or lines, then you can begin less aggressive in your pad selection with a good polish. Now in my opinion, there are two thought processes when it comes to pads. 1st. use a heavy compound/polish with a more generic pad.. IE white(light cut). This allows the product to do most of the work. 2nd. Use a lighter quaility compound/polish and change the level of pad cutting.(I like this method ) Determine your school of thought and stick with it. Remember that starting less aggressive means you can always do more section passes or heavier product if the problem area still exists. Starting heavy may induce more problems than you bargined for.
bigdriver4u is offline
Old 04-04-2012, 10:16 AM   #7
Quote:
What gives?
Dan.
My recommendation stated it was personal preference and it was targeted at a "new" machine user only working on their personal vehicles.
I firmly believe the type of foam you use is the least important factor when it comes to end-results as long as you,
  • Use the right tool for the job
  • Use good quality products
  • Use the right technique
And that's because the quality of ALL foam pads now days is so high.
How's that?
Old 04-04-2012, 10:23 AM   #8
Forgot to tell you that I use Lake country CCS normally. I've just migrated to the LC Hybrids and they are freaking awesome. But, I detail for a living and these pads allow me to cut faster clean up easier.
Old 04-04-2012, 10:38 AM   #9
Member
Well when I clayed it the first time I thought the paint was "ok" (it is a truck afterall), there were swirls and quite a few light scratches. Some of that was hidden by the Z-5, but I am pretty sure they will show right back up once I strip it back down to bare paint. I have to do the color chip first, my mud tires stick out quite a ways and they ding the heck out of the paint, so all that has to get fixed. So I really wasn't sure where to start as far as the pads, but going less aggressive makes sense.
Old 04-04-2012, 10:39 AM   #10
Member
Oh and Mike I am buying your e-book when I get home tonight, that way I can use if for reference out in the garage and still hit the forum if I need to
Driver that helps a bunch....
Oh and I don't know if it matters but this time around the truck is getting the dodo treatment, or Z-2/Z-5 with dodo over the top.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Had really bad luck with Megs MF pads, wrong technique? szjalo Auto Detailing 101 3 03-04-2012 02:30 PM
Motorcycle Scratches on New Motorcycle. jhkunkel Auto Detailing 101 25 03-02-2012 05:21 PM
MF Pad System...Devil's Advocate Thread Spicy McHaggis Wet-Sanding, Cutting & Buffing 158 02-22-2011 10:16 PM
Mega Cyclo Polisher Kit admin New Car Care Products 13 04-21-2006 02:40 PM
» May 2013
» Car Care Brands
