» Official Detail Fest 2010 Information Thread!! | |  | |
06-01-2009, 03:25 PM
#1 | | Senior Member
| Just Got Flex, have they fixed the backing plate issues?
Hi everyone,
Just got my flex 3401 last thursday. This thing feels really well built. Now just one question...
Before I use it for my first polish and wax, i had searched alot on this forum and others regarding what I should do when I had heard about the whole backing plate issue.
I feel bad creating a whole new thread about this, but I have searched for more recent threads and posts about what i should do to make sure this doesn't happen with mine. I had read that people put oil on the felt ring and tighten the bolt of the backing plate. Now, the first thing I did when i got the Flex was tighten the bolt of the backing plate because when i called Bobby from Autogeek, he had said all you should have to do is follow the instructions in the manual and tighten the bolt holding the backing plate. He also had mentioned that the backing plate issue happened a while ago and that I shouldn't worry or have to do anything out of the ordinary to have a perfectly running flex 3401. Now, I was wondering if anyone hadn't oiled the felt ring and run into any problems. I didn't really want to remove the assembly and start removing things and oiling them.
I figure its a new machine and should I have to do this? Am i risking anything if I don't?
Basically, has anyone not oiled the felt ring on their recently purchased flex 3401 and not had any problems?
Also Might anyone have a picture of the felt ring. Is it as simple as taking of the backing plate bolt and removing a felt ring?
Also could i use motor oil, as that is all that i have at the moment.
Thanks again guys for your help. And yes i did use the search button..lol
06-01-2009, 04:32 PM
#2 | | Senior Member
| Re: Just Got Flex, have they fixed the backing plate issues?
the backing plate problem is such a small minor majority, to literally of the thousands and thousands they have sold. taking some pre-cautions ensures to be on the safe side. don't know if you've seen this thread yet, here you go... FLEX XC3401 problem
06-01-2009, 04:37 PM
#3 | | Member
Fwiw. Several months ago a guy on Autopia, spoke with someone at Flex. A rep told him to lube the felt ring with garage door spray lube.
I receive my Flex a few weeks back, and oiled the felt ring just in case. Also, it was said don't over tighten the bolt on the Flex.
06-01-2009, 05:01 PM
#4 | | Moderator
My felt ring damaged the backing plate, but AG stepped in with a new one and no issues since. I believe I was in the minority and have heard of maybe 1 complaint since and likely from the same batch.
It should be noted, no damage to car nor paint.
06-01-2009, 05:08 PM
#5 | | Senior Member
I haven't removed the backing plate yet... does the felt ring come off?
does it have to be submerged in oil?
Also I don't believe I have any spray lube like you had mentioned, however I would just have wd-40, some motor oil and some after run oil for a nitromethanol r/c engine. Any ideas if these work?
06-01-2009, 05:12 PM
#6 | | Senior Member
| Re: Just Got Flex, have they fixed the backing plate issues? Quote:
Originally Posted by mixmaster209 I haven't removed the backing plate yet... does the felt ring come off?
Also I don't believe I have any spray lube like you had mentioned, however I would just have wd-40, some motor oil and some after run oil for a nitromethanol r/c engine. Any ideas if these work? | Get some machine oil, sewing machine oil or gun oil.
06-01-2009, 05:37 PM
#7 | | Moderator
I would warn all to heed the directions and tighten backing plate prior to first use, might save a backing plate or two.
06-01-2009, 06:26 PM
#8 | | Senior Member
Thought i remember someone saying they used synthetic motor oil on a thread somewhere for the felt ring?
Shouldn't it do the same work as garage lube seeing as its made for high temperature engine internals?
What could happen if i use this instead of the other stuff. I really don't have any sewing machine oil, gun oil, or general machine oil. sorry |
06-01-2009, 07:38 PM
#9 | | Senior Member
If garage lube like this is what the flex representative recommended for the felt ring 3-IN-ONE Professional: 3-IN-ONE Garage Door Lube
Then wouldn't wd-40 do the trick? seems like the same product.
My only concern is that don't products like this end up drying out?
Would it have to be applied every time the machine is used?
Sorry i'm asking a lot of questions, just want this machine to last me a long time without having any problem. :P
06-01-2009, 10:40 PM
#10 | | Member
This is what a flex rep told this person. WD-40 doesn't work like this stuff I wouldn't imagine. Supposedly this stuff dries to a gel and sticks to the felt, or whatever else for a long time. Again according to this poster.
I guess if anyone has questions about it, they could always call Flex and see what they tell them.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
