Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Flex Polishers
Featured Photos
by elkphoto
Exterior Gallery
55 photos
31 comments
by admin
Exterior Gallery
55 photos
31 comments
by admin
531 photos
8 comments
by admin
531 photos
8 comments
» Autogeek Car Care Products
Auto Detailing Facts, Tips & Tricks
Reply
Thread Tools Display Modes
  #1
Old 06-02-2008, 10:04 AM
Flex questions
Hi all,
Quick questions for those working with the flex.
I've been using a PC, recently picked up some 5.5" Lake pads to supplement my original 6" ones. Also have a 3.5" backing plate and have been using the 4" pads to do spot areas and also for smaller areas (bumpers, 'c' pillars, etc.)
I just bought a flex. I'll obviously be using my 6" pads but am curious about something. I know that the increased power of the flex will take care of the corrections and I won't need the 4" pads for that, but how do you use the larger pads on the flex in the small areas? If the pad needs to stay flat but hangs out out over the area being polished.
Also, I've never been TOO concerned about exactly centering the pads on the PC, but with the forced rotation of the flex it's probably more important. What methods do you use to center the pad on the bp? Do you mark the pad edges?
Thanks,
Russ
  #2
Old 06-02-2008, 11:41 AM
Re: Flex questions
Ok. Here's my take...
You always will need smaller pads do do certain jobs in tight areas where it may overlap with trim, windows, etc...
Though the Flex is powerful enough to do what you want it to do, a smaller pad is still needed
For what I understand, you can send your backing plate to Edge to have them make a conversion that will enable you to use all of their different size pads
I'm not up to speed on how it works exactly, as I'm also collecting info on this as I want to order a Flex with this set-up myself
__________________
-Goose
2002 Z06 Bone Stock
2001 ZR2 Bone Stock
Free Our Troops!
  #3
Old 06-02-2008, 03:22 PM
Re: Flex questions
On the Flex and most rotary the backing plate has a hole in the center about the size of 5/8 or 3/4 deep well socket and the same size holes in the LC pads and most others pads. Just stick the deep well socket in the hole on the back plate and use it as guide to center that pad. Of coarse, remove the socket before buffing…
__________________
-Dennis
  #4
Old 06-02-2008, 04:25 PM
killrwheels@autogeek's Avatar
Moderator
Re: Flex questions
until the Edge adapter or smaller backing plate is offered for Flex, you might wanna keep the PC for small and hard to reach areas.
  #5
Old 06-02-2008, 04:37 PM
Re: Flex questions
Yeah, that's what I thought. I was hoping to be able to sell the PC to recoup some of the flex costs, oh well, never hurts to have a back up.
  #6
Old 06-02-2008, 04:51 PM
rwisejr's Avatar
Talking Re: Flex questions
Quote:
He I have the Flex and trhe edge adapter .But always good to have a back up unit.Things happen . Currently My PC is setup with the carpet brush and is now handling carpet duty.
__________________
Club Flex Member ;Club SystemoneMember
Ron !!!!!
  #7
Old 06-02-2008, 06:04 PM
Re: Flex questions
Like rwisejr, PC has more than one use, so one should keep their PC even when having Flex if they can afford it.
  #8
Old 06-09-2008, 04:28 PM
Re: Flex questions
Thanks for the replies. I will be keeping the PC as recommended.
New question: I've read here and elsewhere that I should add some oil to the felt ring, some have said " a dab " and others "soak". Any advice on how much to put on?
  #9
Old 06-09-2008, 05:07 PM
MadOzodi's Avatar
Re: Flex questions
I wouldn't say soak it, because it'll sling off onto your car's paint. I would dab and allow it to soak through after a few hours. Whatever you do, don't get the felt ring wet. I just purchased a 3.5" BP for my UDM to use in the tight spots and on the A-pillars.
__________________
07 Cosmic Blue Mazdaspeed3
00 Black Mustang GT - Spring Ed. (for sale)
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Flex Problems, NOOOOOOOOOOOOOO! Excessive Detail Porter Cable 7424 & Buffing Pad Forum 50 05-24-2008 09:19 PM
Another Flex Review Excessive Detail Flex Polishers 25 02-25-2008 09:04 PM
Flex 3401- how safe is it? budman3 Flex Polishers 73 01-09-2008 03:38 PM
Update on the FLEX XC3402 VRG Dual Action Orbital Polisher Dwayne Flex Polishers 14 01-02-2008 03:47 PM
Review of Flex XC3401 VRG wolfpacker92 Flex Polishers 38 11-16-2007 08:58 PM
» September 2008
