car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Flex Polishers
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 22.58%
28 Votes
DVD - 12.10%
15 Votes
Digital PDF Download - 65.32%
81 Votes
Total Votes: 124
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 05-12-2008, 04:41 PM   #81
mixxer's Avatar
Re: FLEX XC3401 problem
i dont feel soaking a felt spacer in oil is a fix to a design flaw,to me its a bandaid not a resolution.
__________________
Detailed Reflections
mixxer is offline
Old 05-13-2008, 12:03 AM   #82
m4gician's Avatar
Then what can we do? Look into aerospace grade rubber gaskets meant to work with high heat?
__________________
AP Auto Detailing & Car Care
"Care, Pride, Passion"
Serving the Greater Toronto Area 24/7, 365.
Direct e-mail: info@apautodetailing.ca
m4gician is offline
Old 05-13-2008, 10:11 AM   #83
m4gician's Avatar
Quote:
Originally Posted by ZoranC View Post
Rubber gaskets? No, purpose of that felt is not to serve as gasket, rubber would be making situation even worse.
For now I would suggest following exact recommandation of PowerHouse because even if they are not having best solution they are main distributor and repair center so if anything happens there will be no finger pointing, warranty would be valid and it would be their responsibility to address it.
I like that solution. If this continues to be a problem, I'll just upgrade to the edge 2000 or 3000 adaptor and pads and sell all of my 6.5 pads for the flex.
__________________
m4gician is offline
Old 05-13-2008, 04:08 PM   #84
mixxer's Avatar
Quote:
that was my thinking also.
__________________
mixxer is offline
Old 05-13-2008, 04:51 PM   #85
budman3's Avatar
While I don't have a Flex DA the Edge adapter for it uses the stock backing plate by Flex, so I'm not sure that is going to be a solution to the problem with the felt ring and gears wearing down and such.
budman3 is offline
Old 05-13-2008, 10:24 PM   #86
MadOzodi's Avatar
Quote:
Really? Damn, my dreams of using the Edge Flex DA adapter to fit a 3M/Meguiar's backing plate to it have gone up in...well, felt smoke.
__________________
07 Cosmic Blue Mazdaspeed3
00 Black Mustang GT - Spring Ed. (for sale)
MadOzodi is offline
Old 05-14-2008, 09:25 AM   #87
budman3's Avatar
Quote:
Here is a quote from Aaron (The Edge) on Autopia:
"You are VERY WELCOME! We are just sorry that we can't make them fast enough but due to the fact that at this point we require a standard Flex backing plate in order to modify and fabricate into the Edge2K Flex conversion, and Flex themselves are backordered on machines and therefore plates, it may take some time before we can really get alot of these out in the marketplace. That being said we may start another program whereby you can send in your current plate for the conversion. This will will speed the turn around time and save you a few bucks in the process."
budman3 is offline
Old 05-22-2008, 09:11 PM   #88
Bri
Member
What hex screw are you talking about? Is it the hex screw shown below: if not, can you please explain further on what to do?
I did tighten this bolt down and it still had room to go.
Also, I noticed that my Flex is really REALLY noisy and it vibrates a lot! It seems that the black piece in between the white part and the metal part is loose. (Shown in picture below) Even if I already tightened the bolt shown above. Is this normal?
Thanks guys!
Bri is offline
Old 05-24-2008, 05:34 PM   #89
Member
My flex came in last week, so far I have used it only for a few hours tops.
I have to be honest and say I forgot to check the bolt before my first use. After the first hour of use it came to me that i didn't check the bolt. It was a little lose that's not to say it was lose before use. The vibration could have loosened it up. The back plate has minor scuffs on it. I tightened the back plate up and haven't had any issues since. I keep checking to see if bolt loosens up and the backing plate. All looks good so far.
Bridges is offline
Old 06-07-2008, 11:50 AM   #90
Member
ger42's Avatar
3 rd time I've used it and today it started to fling white particals. Plate has melted some. I wonder if Edge can modify it this way or do I need to get it serviced.
ger42 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Any word on next Flex XC3401 shipment? MadOzodi Auto Detailing Tools and Accessories 4 03-20-2008 04:47 PM
Another Flex Review Excessive Detail Flex Polishers 23 02-25-2008 09:04 PM
Update on the FLEX XC3402 VRG Dual Action Orbital Polisher Dwayne Flex Polishers 14 01-02-2008 03:47 PM
Flex XC3401 VRG Orbital Polisher (Dual Action) Jason New Car Care Products 9 12-04-2007 12:15 PM
Review of Flex XC3401 VRG wolfpacker92 Flex Polishers 38 11-16-2007 08:58 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Griots Garage
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
