car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Flex Polishers
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 22.40%
28 Votes
DVD - 12.00%
15 Votes
Digital PDF Download - 65.60%
82 Votes
Total Votes: 125
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 03-12-2008, 09:43 AM   #31
Deep Gloss Auto Salon's Avatar
Re: FLEX XC3401 problem
Quote:
Originally Posted by RTexasF View Post
Thanks Bud. Is there just one set screw that holds the plate to the mechanism?
Yup, it's one screw at the center of the BP that is recessed to be below the flush line of the BP velcro
__________________
Deep Gloss Auto Salon LLC
Deep Gloss Auto Salon is offline
Old 03-12-2008, 11:43 AM   #32
conan777's Avatar
Darn, I used my Flex yesterday and sure enough I started smelling that burning smell and almost had a heart attack thinking that I was burning through paint on an 08 Ashton Martin! Doh! It only happened when I applied some pressure. I just backed off the pressure and it was ok. So can I just tighten the backing plate and that will correct the problem?
conan777 is offline
Old 03-12-2008, 11:44 AM   #33
I didn't tighten the BP when i got mine....is that what's causing the premature wear. They should tighten the BP next time they send the units to customers. Its a little ridiculous hoping the customers will tighten the BP without any notice/instructions.
gasterus is offline
Old 03-12-2008, 12:48 PM   #34
Quote:
Assuming it was loose, that may solve the issue...
Did you tighten it when you received it?
__________________
Old 03-12-2008, 01:01 PM   #35
Russecu's Avatar
I took my backing plate off when I received mine to check out the gear driven rotation. I then tightened the backing plate screw snuggly. No problems so far.
Russecu is offline
Old 03-12-2008, 01:30 PM   #36
MadOzodi's Avatar
Nice investigative questions MotorCity...I will for sure be tightening down my BP first thing after I receive my Flex.
__________________
07 Cosmic Blue Mazdaspeed3
00 Black Mustang GT - Spring Ed. (for sale)
MadOzodi is offline
Old 03-12-2008, 01:47 PM   #37
blkyukon's Avatar
My question to everyone that has had this problem...what kind of pressure are you applying?
When I tested it I applied moderate to heavy pressure (for a few passes) with no ill effect.
Are you applying pressure at an angle/on the side of the pad? There is very little clearance between the BP and machine...I don't think it was designed for heavy pressure.
A few things I noticed with the Flex 3401 is you don't need to add pressure like with a PC/UDM for it to cut...if you need more cut slow down the passes. The direct drive with slower passes will help with the cutting abilities of the machine. I have never felt the need to add more then light/moderate pressure (only at times) and use nothing more then the weight of the machine 95% of the time.
I personally polish with it like I do with a rotary & let the machine speed/pad/polish do the work.
blkyukon is offline
Old 03-12-2008, 01:47 PM   #38
Quote:
This is a perfect example of my job traits seeping out into my *private* life...
Sounds like a good plan to all users to tighten the BP when you initially get the machine - to be on the safe side, I plan on checking it prior to each use
__________________
Old 03-12-2008, 01:54 PM   #39
I guess nobody is reading (previous posts I have made on tightening and use of two washers).
Still, can anybody tell me where that brownish tube is coming from as neither of my XCs has it?
ZoranC is offline
Old 03-12-2008, 02:29 PM   #40
MadOzodi's Avatar
Did Al's response in post #11 not cover it? I'm not sure if that's what you're talking about.
__________________
MadOzodi is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Any word on next Flex XC3401 shipment? MadOzodi Auto Detailing Tools and Accessories 4 03-20-2008 04:47 PM
Another Flex Review Excessive Detail Flex Polishers 23 02-25-2008 09:04 PM
Update on the FLEX XC3402 VRG Dual Action Orbital Polisher Dwayne Flex Polishers 14 01-02-2008 03:47 PM
Flex XC3401 VRG Orbital Polisher (Dual Action) Jason New Car Care Products 9 12-04-2007 12:15 PM
Review of Flex XC3401 VRG wolfpacker92 Flex Polishers 38 11-16-2007 08:58 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Poorboys Wolrd Polishing & Detailing Products
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
