Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
  1. #31
    Member
    Oct 2016
    35
    Re: Horrible DA grey scale marks?!
    Here's the first picture of swirls you posted...
    To me this DOES NOT look like micro-marring, it simply looks like you didn't remove all the deepest swirls and scratches during the first step, i.e. the correction or compounding step.
    Here's the second picture of swirls you posted...
    So if you started with the swirls shown in the second picture and you've worked the finish to what you show in the first picture, it looks to me that you need to spend more time compounding or tweak your technique.
    The FLEX 3401 is a a BEAST of a tool meaning it has all the power you need to tackle this car. Like others have said, M105 can be a tick on the difficult side to work with and M205 can be more finicky to finish out with on softer paints, it's usually really good on harder paints.
    I have found free spinning orbital polishers (ANY of them), to require less technique and are less dependent on the pad and product to finish out perfect. I talk about this in a write-up I posted 4 years ago in 2012 with this old 2-door sports car...
    Christmas Detail - Ferrari P4 - Move over Rudolf
    See post #32
    This was something I said 4 years ago and I stick by what I said back then .
    Thank you for the input! It's much appreciated!! I guess I should have written this post better. These pictures are what's left after removing swrils.
    1. first cut with a rotary-paint was horrible. After this step paint was near flawless but had swrils.
    2. Corrected the paint with my flex that caused this effect. No matter what I used, pad wise, it still created this spider Web appearance.
    Sent from my SM-N920V using Autogeekonline mobile app
  2. #32
    Jun 2009
    Stuart, Florida
    39,357
    Quote Originally Posted by virus911s View Post
    I think I read that you had ordered some Menzerna compounds and polishes?
    If so, re-polish a section of an area you polished with the M201 using the FLEX 3401 and a fresh clean foam polishing or finishing pad and then inspect the results.
    This should tell you if it's product related or pad or tool.
    Menzerna and Meguiar's use very different abrasive technology.
    IDA Board Member
    CD-SV, RT
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  3. #33
    Member
    Oct 2016
    35
    Sounds like I'm headed to autogeek.com haha. I'm not familiar with the Menzerna line up. What do you recommend for a compound, Polish and finishing polish in their line up?
  4. #34
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    400 and 3500 are a quality combo.
  5. #35
    Senior Member HateSwirls's Avatar
    Jun 2013
    3,583
    What pad did you use with each tool?
    Ended up using the orange Lake Country pad
    Tried the white first with both machines and the Rupes was the best choice for that particular job
    Sent from my iPad using Autogeekonline mobile app
    cajundetailingbykevin.com
    vpcajun@gmail.com
  1. Kitchen Scale
    By Infiniti in forum Off-Topic
    Last Post: 04-24-2017, 02:18 AM
  2. Abrassive Scale for Marine31
    By Coastalf350 in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-17-2016, 08:54 PM
  3. Horrible swirl marks!
    By dunston in forum Auto Detailing 101
    Last Post: 10-27-2013, 03:16 PM
  4. Compound Aggressiveness Scale
    By hernandez.art13 in forum Auto Detailing 101
    Last Post: 04-21-2013, 11:52 AM
  5. Clay Bar Aggressiveness Scale
    By Mister B in forum Ask Mike Phillips your detailing questions!
    Last Post: 10-27-2009, 10:15 AM
