Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Super Member WAXOFF's Avatar
    Jun 2012
    Just south of the Burgh
    1,283
    Re: Flex 3401 heat question.
    I called Flex about this and was told if it gets too hot there is a sensor inside and it will shut down until it's cool enough to use again.
    2011 Compass Latitude Bright Silver/ 2017 Nissan Rogue SV AWD Premium Glacier White
    REFLECTIVE IMAGE DETAILING
    Feb 2011
    Minot, ND
    12,365
    It is normal for this machine to generate heat. Even more so when you crank it up to the higher speed settings.
  3. #13
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Heat is a by product of the forced/gear driven design. 3401 is the most "mechanical" type polisher available.
  1. Flex 3401 maintenance question
    By Toolhead in forum Flex Polishers
    Last Post: 02-07-2018, 06:34 AM
  2. Flex 3401 heat issues
    By apierce1289 in forum Flex Polishers
    Last Post: 10-22-2015, 07:57 PM
  3. Flex 3401 generates a lot of heat?!
    By Danube in forum Flex Polishers
    Last Post: 12-21-2013, 10:46 PM
  4. Flex 3401 question
    By Hotnes2301 in forum Flex Polishers
    Last Post: 11-08-2011, 11:55 PM
  5. Flex XC 3401 Question
    By JoeD in forum Auto Detailing 101
    Last Post: 06-20-2009, 09:21 PM
