I will take pics of my 3401 and the PE-8 together. I have a toolbox that both fit nicely with all the backing plates (for both). I will be getting the 1" and 2" BP w/Pads. I already have the 3" BP and numerous 3" & 4" Pads for the PE-8.
All I can say is based on my limited experience toying around with the PE-8 is it worth it? YES!! If you use the Flex 3401 going to the PE-8 has been an easy transition (so far). You are used to the forced rotation and when you move to the PE-8 there is a big difference in terms of less noise and way smoother too!
I would also recommend the 5/8" BP extension piece. I will post pics by tomorrow.
