Re: SEMA Release of Rupes
Originally Posted by swanicyouth
Anyone know the amps/watts of these new machines? Are they less, more, or as powerful than the 15/21??
400-450 watts, IIRC.
Here's a link to the BigFoot page with all the specs: Bigfoot | Prodotti
Just read this on another site:
"RUPES is only releasing the LHR12E [Duetto] in complete kit form...not individual tool sales."
Cost was right around $500.
Interesting. Can't find any power specs - maybe I'm just missing it. The Mini still weighs instead over 5 lbs:
According to Amazon, the Griot's 3" weighs 1lb. Is that correct???
Guess the GG6 will still be a best buy.
According to the below RUPES spec-charts: 400W
LHR 12E DUETTO...Random orbital polisher
Technical Data
Backing pad thread......M8
Speed control................√
Weight Kg.................2,6
RPM.................4000-5500
Power W/hp............400
Ø orbit (mm)................12
Ø backing pad (mm).....125
LHR 75E MINI...Random orbital polisher
Technical Data
Backing pad thread......M6
Speed control...............√
Weight Kg..................2,3
Power W/hp.............400
Ø backing pad (mm)......75
I'd say a tad less powerful.
LHR 21ES...Random orbital polisher
Technical Data
Speed control.......................√
Weight Kg.......................2,600
RPM........................2000- 4200
Power W/hp.....................500
Ø orbit (mm)........................21
Ø max polishing pad (mm)....180
Ø backing pad (mm).............150
LHR15ES...Random orbital polisher
Technical Specifications:
Velcro Pad (mm).......................125
Polishing Pad Size Max. (mm).....150
Orbit (mm)...............................15
Power W...............................500
Speed Control.............................√
Weight Kg................................2.2
Revs R.P.M.....................2000-4200
As others have noted, about 400 watts is the AC power consumption. All that tells you is that you can safely run it on a 15 amp circuit simultaneously with another tool consuming about 9 amps.
That number doesn't have a direct relationship with the correcting power at the pad, especially with a free-rotating type of DA where the pad rotation can be stopped to zero rotations while the machine's motor is consuming the full rated power from the AC line, in driving the oscillating portion (where the OPM is applicable) of the dual action.
see this link for specs:
Check Out The New Rupes LHR 75E Mini & Rupes LHR 12E Duetto [SEMA Show 2013] | Ask a Pro Blog
Yeah I saw the kits out there as well. Was hoping that was just something that that site was pushing. That'll probably kill a decent percentage of sales. Although as I was speculating in another thread Rupes may be pushing the integrated tool, pad, liquid (compound/polish) solution. That is unfortunate as I'd say by and large most guys would rather use the pads and products they have on hand.
I had intended on purchasing both new machines, but I'm out if they are only offering them as part of a 'kit'. Hopefully this isn't the case, but if it is, it's a bad business decision in my book.
07 TBSS AWD 3SS (Black) - 09 TBSS 2WD 3SS (Silver)
By B5visser in forum RUPES BigFoot Oribital Polishers
Last Post: 08-23-2017, 06:16 PM
Last Post: 11-02-2016, 05:40 AM
By xxxc5 in forum RUPES BigFoot Oribital Polishers
Last Post: 01-13-2015, 08:20 PM
Last Post: 11-24-2013, 03:22 PM
By Miracle in forum Auto Detailing 101
Last Post: 01-30-2013, 12:04 PM
