Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Circular Polishers -Rotary Polishers - High Speed Polisher
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-24-2011, 08:13 PM   #1
What kinda rotary backing plate do you use for 6.5" pads?
Hey guys, what is a good backing plate for a rotary to be used with 6.5" pads?
What size should I be getting?
Kaban is offline
Old 04-27-2011, 01:03 AM   #2
Re: What kinda rotary backing plate do you use for 6.5" pads?
Nobody can help?
Kaban is offline
Old 04-27-2011, 01:23 AM   #3
Lasthope05's Avatar
Megs solo backing plate is very nice for 6.5" pads. I bought two and cut one down to 3.75" to use 4" pads because there isnt a thick foam one on the market.
__________________
Alan T.
Lasthope05 is offline
Old 04-27-2011, 02:32 AM   #4
93fox's Avatar
you might want to get a 6'' backing plate for 6.5 pads. look here, Hook and Loop Backing Plates, Velcro brand hook & loop backing plate, meguiars backing plates, lake country backing plates it dosent have to be a specific brand but ive heard alot of good things about the meguiars ones.
__________________
Good afternoon! my name is Oscar, and I hate orange peel!
93fox is offline
Old 04-27-2011, 04:32 AM   #5
tuscarora dave's Avatar
I use this plate 6 Inch Rotary Backing Plate Use this backing plate with the Lake Country 7.5 inch pads. The 6 inch backing plate fits perfectly into this recess so for 6.5" and larger pads on my rotary. It has been a trouble free backing plate and holds the pads very securely.
tuscarora dave is offline
Old 04-27-2011, 06:28 AM   #6
BobbyG's Avatar
I use a 6" Lake Country backing plate for my 6 1/2 inch pads. Because the pads and backing plate is close to being the same size I pay particular attention to centering the pad on the plate..
__________________
BobbyG is offline
Old 04-27-2011, 06:36 AM   #7
SeaJay's's Avatar
Same here.
SeaJay's is offline
Old 04-27-2011, 07:27 AM   #8
Director of Training
Mike.Phillips@Autogeek's Avatar
Here's an article I wrote for 5.5" and 6.5" pads and the flexible backing plates you can use with them. If you've never used a flexible backing plate, I can't recommend them enough.
Here you go...
Flexible Backing Plates
Flexible Backing Plates provide,
  • An extra level of cushion when using a rotary buffer which helps you when buffing on curved panel and over body lines.
  • The flexible foam interface heps to distribute pressure more evenly over the face of the buffing pad.
  • They can also make the buffing process less aggressive as compared to using a stiff backing plate which can help to reduce swirls.
Currently we have two flexible backing plates besides the flexible backing plate in the 1-Pad system, which is specific to the 1-Pad buffing pads.
  1. The Flex-Foam Heavy Duty Rotary Backing Plate, which has a 5" Diameter
  2. The Meguiar's Easy-Buff Solo Backing Plate, which has a 6" Diameter
Below are some pictures to show the size of the backing plates relative to some popular buffing pads to help you get an idea of the fitment of the backing plate to the hook-n-loop interface on the back of the buffing pads.
Flex-Foam HD Rotary Backing Plate
Flex-Foam Backing Plate on a 5.5" CCS White Polishing Pad
Flex-Foam Backing Plate on a 5.5" Cyan Hydro-Tech Pad
Flex-Foam Backing Plate on a 5.5" Blue Finishing Flat Pad
Flex-Foam Backing Plate on a 5.5" on a Super Soft Gold Jewelling 6" Pad
Meguiar's W66 Solo Backing Plate
M66 Flexible Backing Plate on a 7.5" DuroWool 100% Twisted Wool Cutting Pad
M66 Flexible Backing Plate on a 7" Kompressor Orange Light Cutting Pad
M66 Backing Plate on a 6.5" CCS Red Ultrasoft Finishing Pad
Note in this picture and all the above pictures the extra backing and or foam that sticks out past the outer edge of the backing plate. You want this extra material as a safety margin to help prevent running the outer edge of the backing plate into any painted areas, or around trim or other components like side view mirrors, rear wing spoilers, etc.
Both of these flexible backing plates are excellent backing plates to have in your tool chest to go along with your rotary buffer.
All of the above backing plates and pads work great with all the rotary buffers on Autogeek.net
Rotary Buffers
__________________
How-To Articles
Live Broadcast Videos & Pictures
Facebook
Mike.Phillips@Autogeek is offline
Old 04-27-2011, 07:47 PM   #9
Thank you all so much my friends!
I got a few good 5" (125mm) backing plates that I will try out with my 6.5" pads. I think I am still going to pick up a LC 6" pad though.
Lasthope05 - Gloss-It actually has a 3" Flexible backing plate (with a really thick foam layer) to use for 4 inch pads. It's gonna be around $40 with shipping though... kinda pricey.
This one:
Gloss-it 3 Evo Rotary Backing Plate
Kaban is offline
Old 04-27-2011, 09:50 PM   #10
Lasthope05's Avatar
This one:
I know about the 3" backing plate from gloss-it/rubbish boys UK, but I dont like the over hang. With such a small pad you want the full contact area of the pad as you are concentrating on a small area.
The same with with a 6.5" pad. I dont like using a 5" backing plate because when you apply pressure to the pad it is not evenly distributed and the overhang just mushrooms up.
__________________
Alan T.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Video: The Flex 3403 Rotary Buffer – How to remove Sanding Marks after Dampsanding Orange Peel Mike.Phillips@Autogeek Circular Polishers -Rotary Polishers - High Speed Polisher 24 01-26-2012 07:59 AM
Vector polisher vwman2 Ask the Expert featuring Mike Phillips 17 03-22-2011 01:53 PM
Rotary Pad sizes, backing plates, confusion! Kris R Ask the Expert featuring Mike Phillips 6 01-08-2010 11:00 PM
Using 6.5" pads with 5.0" backing plate D_Nyholm Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 22 06-11-2009 09:10 PM
UDM Backing PLate Reddwarf Questions about the Porter Cable 7424XP, 7424, 7336, Griot's and Meguiar's Dual Action Polishers 6 08-22-2007 06:46 PM
» May 2013
» Car Care Brands
