Meguiars Dual Action Polisher G110
Circular Polishers -Rotary Polishers - High Speed PolisherDiscuss Meguiars Dual Action Polisher G110 in the Buffers and Polishers forums; Originally Posted by killrwheels@autogeek
I think it was done to try and mimic the movement/speed while using the ...
I think it was done to try and mimic the movement/speed while using the Flex. Also the PC needs some pressure, the Flex doesnt and that was not represented. The video is simply a basis to show difference in time/correction but most will take away it does reduce the "patience level" a bit.
Get the Flex, you can figure a way around the damaged trigger finger problem.
I'm going to order it. Once it arrives here in Harlingen THEN you can venture your 30 mile trip here. Just make sure you bring your Cyclo, and the other items in your ride, so we can go to my buds body shop.
