car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Buffers and Polishers > Circular Polishers -Rotary Polishers - High Speed Polisher
» Official Detail Fest 2010 Information Thread!!
» Current Poll
What Discovery show do you watch most?
Overhaulin' - 25.78%
58 Votes
Deadliest Catch - 16.89%
38 Votes
Motor City Motors - 0.89%
2 Votes
Storm Chasers - 1.33%
3 Votes
Dirty Jobs - 17.33%
39 Votes
Man vs. Wild - 7.56%
17 Votes
Shark Week - 4.44%
10 Votes
Cash Cab - 1.33%
3 Votes
The Colony - 0.44%
1 Vote
MythBusters - 24.00%
54 Votes
Total Votes: 225
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 02-27-2009, 11:17 PM   #11
dsms's Avatar
Re: rotary trouble
Heres a quick video of me finishing down an M3 via Rotary. Granted I am using a very fine polish to jewel the paint you get the idea.
Try your best to be fluid, do not force the machine to do anything it doesnt want to but have a firm grip. Nice fluid motions are key IMO. Please note for correction purposes I would be making much slower passes.
Here is another video of my technique on an NSX, no its not a side panel but the same fluid motion applies. Im still doing light correction work in this stage so my passes are slower
dsms is offline
Old 02-28-2009, 11:32 AM   #12
RaskyR1's Avatar
Re: rotary trouble
^^^^^Lefty!
__________________
Quote:
Originally Posted by CieraSL View Post
Mirror, mirror against the snow, tell me who hast detailed thee so?
RaskyR1 is offline
Old 02-28-2009, 12:02 PM   #13
dsms's Avatar
Re: rotary trouble
^^ I don't get it? I'm a righty
dsms is offline
Old 02-28-2009, 12:08 PM   #14
RaskyR1's Avatar
Re: rotary trouble
Quote:
Well you have your left hand on the trigger/shaft of the rotary....I've just never seen anyone use the rotary like that, it's always been left hand on the handle and right hand on trigger. Nothing wrong with it...I was just giving you a hard time.
__________________
RaskyR1 is offline
Old 02-28-2009, 02:17 PM   #15
dsms's Avatar
Re: rotary trouble
Quote:
Thats weird, I never thought of people doing opposite the way I do. I just figured my right hand being the dominant one would be better for driving the head of the polisher whereas my left hand would be more suited to simple modulating the trigger.
dsms is offline
Old 05-14-2009, 09:52 PM   #16
24 HR Queue
Re: rotary trouble
it seems that the pad wants to dig into the car
stardvd555 is offline
Old 05-14-2009, 10:49 PM   #17
HMFIC's Avatar
Re: rotary trouble
Quote:
Originally Posted by rousher99 View Post
to answer the questions i am using a heavy black foam pad from car brite and the product was a light compound from car brite also. i think my problem was not having enough product, and the pad was geting dry.. and when i had the pad flat it would "walk" on me, i will try more tecniques. thanks for the advice
Ya you didnt have enough product. I like to use a very light spray of distilled H2O and work it into the pad with my thumbs before adding product. Give the Lake Country CCS pads a try.
HMFIC is offline
Old 05-15-2009, 09:22 AM   #18
Member
Re: rotary trouble
i am having alot of trouble using a rotary on the sides of cars. it seems that the pad wants to dig into the car. but i didnt know if there was a tecnique for the vertical panels. i always am sure i have plentyof product and the pad is primed
Morning,
Let's start from the beginning with why rotary pads bounce at times...my comments are from personal experience from over the years of using a rotary polisher.
Foam buffing pads have a certain density to them. As the pad is rotated over paint's surface with the rotary, the pad will change shape due to downward pressure, speed/rpm, foam density, and the pad's saturation. At the same time, the pad is fighting to regain its natural shape. What do we do? Naturally as the pad begins to lift, move around or bounces we tend to push even harder which usually aggravates the problem even more.
There are a few reasons why pads hop:
1. Not enough product
2. Too much product
3. Your body not being square to the surface
4. Residue from previous step not fully removed
5. Contaminants on the surface causing the compound to grab and thereby gum up.
Having too much product is just as bad as not having enough product. Too much product often leads to a saturated pad, thereby loosing the effective cut of the foam pad. Moreover, as the pad becomes saturated, it begins to lose its ability to go back to its natural shape. Hence the pad will often distort, causing the foam pad to grab even more. If you think about, the DA polisher causes the product to go from the outside edge of the pad towards the middle, but the rotaries direct drive causes the product to be forced to the edges causing the pad to distort as the pad becomes heavily saturated. The higher the speed the more this problem become apparent.
The solution: Change out to clean fresh pads way more often and use a slower speed of around 1200 rpm.
Not enough product also causes issues. The foam pad's density will cause the pad to grab if there is not enough lubrication from the product. Hence, many people including me, prime the pad thoroughly before using. This allows the pad to buff smoothly over the surface. This is also why foam cutting pads tend to grab way more than a foam finishing pad. Obviously, there is the foam cell structure etc involved, but regradless, a dry pad is bouncing pad.
Now with the sides of vehicles, there is another element being added to the mix, the angle of buffing. On the hood or another horizontal panel, most people can adjust the downward pressure easily, making the buffing process smoother (as long as the pads are not over or under saturated with product). But on the sides, one tends to push harder to keep the buffer against the paint as unlike the horizontal surfaces, gravity is not helping.
Solution: The best thing to do is to square yourself to the panel you are buffing. In other words, if buffing on the door, rather than reaching down having your arms out-stretched which causes an unnatural angle and a leverage point, by sitting down on the ground, squaring yourself to the panel, you will be able to control the rotary much better. Lower panels, may require laying on the ground polishing upwards against the panel. If you stand up and buff at a downward angle, your out-stretched arms become fatigued quickly. Then as the buffer starts to bounce, you apply even more pressure and the hop will get worse and worse.
Finally, before each buffing step, wipe down the panel thoroughly to make sure all previous buffing residue is removed before proceeding to the next step. Otherwise, while the old adage "like dissolves like" is often true, two different products mixing may cause the product to gum up leading to certain buffer hop.
Again, this is just from my experience. But I hope it helps!!
Tim
2hotford is offline
Old 05-16-2009, 02:38 AM   #19
24 HR Queue
Re: rotary trouble
2. Too much product
Old 05-16-2009, 06:48 AM   #20
Wendell Jarvis's Avatar
Re: rotary trouble
Quote:
__________________
Vision Detailing
Richmond,KY.40475
859-623-4435
Wendell Jarvis is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Is Menzerna for PC or Rotary? Kris R Auto Detailing University 7 12-09-2008 11:45 AM
My first attempt with Rotary - 35 Ford dennish Show N' Shine 8 07-10-2007 10:58 AM
Pat vs The Rotary Pats300zx Auto Detailing 101 11 07-05-2007 10:01 AM
Rotary Questions? peter w. Auto Detailing 101 2 06-01-2007 08:51 AM
Which pad textures are most common for the rotary? Avengeance Auto Detailing 101 12 11-03-2006 12:11 AM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Griots Garage
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
