Mineral oil
Has any tried using mineral oil on a really dry gelcoat. I was reading the ingredients of 3m's imperial comp and finishing material , and white mineral oil in listed, so I doubt it could harm the surface. I experimented on a small section of a boat. I first rubbed a little in to the gel coat and then wiped off any extra residue. Then I compounded the area, the compound did not get sucked into the gel coat and spread nicely. To me it seamed to cut the same, and actually left a slight trail behind the buffer, allowing me to work the product longer. If you use to much you will loose your cutting ability. I use finish Kare's Big white rubbing compound, dose a decent job, kind or really thick and messy. Any thoughts or comments on this would be great.
Re: Mineral oil
Adding a squirt of mineral oil or baby oil to increase the working time of a compound is somewhat common. Several compounds are designed to work quickly and are often over worked and this is when issues occur. Adding a squirt of either adds lubrication therefore an increased working time is the result.
By lawrenceSA in forum Auto Detailing 101
Last Post: 12-24-2013, 07:11 PM
By kuhli in forum Ask your detailing questions!
Last Post: 11-28-2013, 06:58 PM
By DanS in forum Ask your detailing questions!
Last Post: 04-04-2011, 07:35 PM
By DLB in forum Auto Detailing 101
Last Post: 12-10-2009, 05:59 AM
By orionz06 in forum Auto Detailing 101
Last Post: 02-20-2009, 06:32 PM
