Results 11 to 20 of 27
    Super Member ShineTimeDetail's Avatar
    Sep 2010
    St. Louis/ Fort Lauderdale
    2,032
    Re: Gelcoat is boring
    Megs is like 30 bucks and duragloss is 12. Is there a huge difference? Is power cut much different than 105
    Quote Originally Posted by ShineTimeDetail View Post
    Jeezus! How tall is that truck!
    I have the other half of the picture at home but it's sitting on either 40" Swampers. That truck actually became this truck and my friend Eric still owns it today, in fact last year he went throught and rebuilt it with his two boys...
    This is Eric's truck, I helped Eric build this literally from the ground up as we started with 4" square stock pipe and welded up a custom frame. This was back in 1982 and just this year Eric and his two boys completely rebuilt and repainted this truck. Eric lives on 10 acres of forest land and when we get to Oregon my 10-year old son Rand is going to get to take this baby out into the field and drive it around. (Sitting in Dad's lap of course).
    Believe it or not, this is street legal in Oregon, I should know I've drove it around for years when I lived there.
    That's Eric grabbing the door handle to give perspective as to how tall the truck is, Eric is about 5' 11"
    Okay, now back to gel-coats...
  3. #13
    Sep 2010
    2,032
    How are we supposed to talk about gel coats now??
  4. #14
    Feb 2012
    Ft Myers FL
    54
    And if you want to make buffing oxidized gel-coat as easy on you as possible, clean your wool pad after every section. It add a little time to the overall process but abrading each new section will be easier and your pad and compound will work more effectively and from my experience, the residue wipes off easier when it's not all mixed up with the gunk on the pad from the last section.
    Hi Mike :
    Another thing a guy can do for real chalky gelcoat, is prep the surface.
    Something like a Sia 6120 Siavlies Ultra Fine Nonwoven disc cleans up the
    clutter of dead gelcoat prior to compounding. It is an extra step, but its quick and
    allows the compounds and wool pads to perform better.
    Steve
  5. #15
    Sep 2010
    2,032
    What would polish would you finish with for a compound?
  6. #16
    Feb 2012
    Ft Myers FL
    54
    None, if I was compounding with Buff Magic (Pink) or 3M Imperial Compound.
    My sons love PoorBoys SSR 2.5 polish for the vessals that need more than
    an abrasive AIO but less than a compound.
    I know this may seem harsh if you come from the clearcoat world, but it's not in
    the modern gelcoat world.
  7. #17
    Sep 2010
    2,032
    I cut with this today Norton Liquid Ice Polishing Compound Quart and it cut the super heavy oxidation today but finished horribly! I tried to finish with a lighter polish and a foam pad but is still have bad holograms. How do you finish without holograms. I'm doing a white RV
  8. #18
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    You were pretty young starting out.[QUOTE=Mike.Phillips@Autogeek;688184]Oh yeah...
    This is me racing it on Dexter Reservoir in Oregon...
  9. #19
    Dec 2011
    Pompano Beach, Fl
    1,494
    Except for something 25 years old and complexly oxidized and matte, I can get gloss out of any gelcoat with + wool/rotary/561 and then orbital/ foam/501.....and cleaning pad very often
    Glen -
  10. #20
    Feb 2012
    Ft Myers FL
    54
    We never have problems with holograms in marine gelcoat.
    I would like to believe all gelcoat is the same, but it's not.
    We find that since boat builders use differant maufactures of polyester/resins/pigmants, they
    also finish out a little differant. A Bayliner boat will need less agression than say a Grady White.
    We don't have enough experance with RV's to give any advise.
  1. Gelcoat Wax
    By Corey06 in forum Auto Detailing 101
    Last Post: 10-04-2017, 06:03 AM
  2. Dry gelcoat
    By Theraven in forum Boat & Marine Craft Detailing
    Last Post: 02-03-2013, 04:48 PM
  3. Gelcoat
    By NY-Bondo in forum Products Guides
    Last Post: 01-13-2013, 11:09 AM
  4. Something other than Gelcoat
    By KKYS in forum Boat & Marine Craft Detailing
    Last Post: 09-04-2012, 11:58 AM
  5. Front End Rebuild. BORING!!!
    By hoyt66 in forum Off-Topic
    Last Post: 07-04-2012, 07:07 PM
