Results 21 to 30 of 33
  1. #21
    Super Member Jomax's Avatar
    Jan 2012
    Arizona
    1,422
    Re: Can my boats gel coat be restored
    Any pics of it finished?
    David 2000 Ford F-350 DRW CCLB BLACK/GOLD
    Wish list:
    Everything Mike has in his garage for detailing
  2. #22
    Feb 2015
    Ft. Lauderdale,Fl
    615
    His hands are too tired to type, that was a lot of work!
  3. #23
    Super Member asap2stacks's Avatar
    Mar 2016
    Maryland
    551
    Can my boats gel coat be restored-imageuploadedbyagonline1469220167-182782-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469220182-200704-jpgCan my boats gel coat be restored-imageuploadedbyagonline1469220194-352495-jpg I ended up taking 600 grit wet sand all the way to 2000 grit them buff that out with 3M rubbing compound with Makita rotary buffer
  4. #24
    Mar 2016
    Maryland
    551
    Can my boats gel coat be restored-imageuploadedbyagonline1470009107-342397-jpg
  5. #25
    Jan 2012
    Arizona
    1,422
    Wish list:
  6. #26
    Super Member damaged442's Avatar
    Apr 2013
    577
    Nice Brendella! Lines of that boat are very reminiscent of the Supras of that era. What year? Specs? Definitely don't see too many of them around, that's for sure!
    I appreciate seeing the older slalom tugs still getting some love. I have an 89 MasterCraft Tristar 190 and my father just picked up an 81 19 Skier (Stars and Stripes)
    As you can see, gelcoats can be brought back from what you think may be dead! Great job bringing that back. Mine was almost that bad when I first bought it 12 years ago. As long as you keep it up, its much easier to maintain, as far as oxidation is concerned.
    Follow up all your work with some Collinite 845 or 925 and put that sucker in the water. Post pics after you get it back in the water and in action!
  7. #27
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Quote Originally Posted by asap2stacks View Post
    What did you do to the back quarter? How did it come out?
  8. #28
    Mar 2016
    Maryland
    551
    He are photos of the final results, I loved how it turned out was a complete 180.
    Can my boats gel coat be restored-imageuploadedbyagonline1470133630-211457-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133643-179123-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133653-937448-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133665-715418-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133676-729244-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133687-884279-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133698-769855-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133709-435607-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133725-105398-jpg
  9. #29
    Mar 2016
    Maryland
    551
    Can my boats gel coat be restored-imageuploadedbyagonline1470133826-686144-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133837-568894-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133848-137211-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133859-922207-jpgCan my boats gel coat be restored-imageuploadedbyagonline1470133874-009695-jpg
  10. #30
    Attachment 50557Attachment 50558
    My boat has been sitting for 5 years in the open weather and has built up the oxidation/faded look as seen in the photo. Tomorrow I'm going to paint correction to the hull.
    What grit sand paper for wet sanding should I use I was thinking 1200 grit?
    I'm going to use my Mikita rotary with a wool pad and Meg's marine compound to remove the wet sand scratches.
    Follow up with polishing with my mt300 6" black thin foam pad
    And wax with PC using a black hex waxing pad.
    Will this work I haven't choosing my polish or wax to use yet I was thinking HD speed but idk if I should test that on a boat or not.
    The above process WILL work and I document how to do this EXACT type of gel-coat restoreation in my how-to book.
    So for all the lurkers and forum members that will read this thread into the future if you want a step-by-step outline with specific and detailed instructions, get a copy of my how-to book on this topic. The book shows how to do pretty much every boat detailing procedure using Marine 31 products the the techniques shown will work with any quality brand.
    Paperback book - How To Detail Boats With Marine 31 by Mike Phillips
  1. Holograms in gel-coat boats by Mike Phillips
    By Mike Phillips in forum 2-Day BOAT Detailing Classes - Info & Dates
    Last Post: 01-28-2021, 01:38 PM
  2. Boats, Boats and more Boats
    By attention2detaillhc in forum Show N' Shine
    Last Post: 04-17-2017, 02:31 PM
  3. 2 Boats Wanted - Black Gel-Coat Boat & Pontoon Boat
    Last Post: 05-05-2015, 04:09 PM
  4. Replies: 12
    Last Post: 09-17-2013, 09:24 PM
  5. Replies: 14
    Last Post: 06-24-2012, 11:36 AM
