» Paypal Bill Me Later | |  | |
08-06-2012, 02:58 PM
#1 | | Member
| Best OTC Carpet Combo
Hey guys,
Up until recently, I couldn't find a good method of cleaning carpets, and felt that my service always lacked in this area...
I was using Scotch Gard for auto interiors (the cleaner) and I decided to give some other products a try.
At Wal-Mart, I picked up both Lifter-One and Tuff Stuff Carpet cleaners. Lifter-One worked well, however I used one bottle alone on a Ford Ranger supercab interior, and I don't recommend it to everyone...
The Tuff Stuff was my second option, and was the best by far... I applied the shampoo to the carpet evenly in a mist, and followed it by spraying Folex spot remover evenly over the carpet. I then used a stiffer bristled carpet brush to agitate, and then used my 5hp Rigid Shop-Vac to suck up the excess dirt and product. The carpet looked brand new, and I had to share my good results with all of you... IMG_0809[1].jpg IMG_0810[1].jpg
__________________
Christopher J Messier
Topher's Detailing
Detailing Rig: 2008 Mini Cooper Clubman S
08-06-2012, 04:23 PM
#2 | | Senior Member
| Re: Best OTC Carpet Combo
I have never liked the foaming carpet cleaners that come in a can. They always leave way too much residue and take forever to extract out. Megs APC+ and Folex are now my go to combo for carpets. I also have a "custom" laundry soap that my wife makes that suds up a little if I need to lift excessive dirt out of floor mats, etc. Looks like you got great results with your combo!
08-06-2012, 04:28 PM
#3 | | Senior Member
Looks like your combo worked!
OPC or folex are the ones I use. Folex is available OTC.
__________________ Tim "I have done so much with so little for so long. Now I can do anything with nothing" |
08-06-2012, 06:27 PM
#4 | | Junior Member
I just started using tide laundry detergent today on a very bad interior with a lot of dog hair and it worked amazing I just mixed it 14:1 and sprayed it on and use my extractor to remove to remove it
08-06-2012, 07:04 PM
#5 | | Member
When you use Tuff Stuff and/or Folex for this, using a Shop Vac or equivalent (ie not an extractor) to finish it off ... after the carpet dries completely ... if you were to dampen your hand and rub the carpet, would it feel soapy?
Thanks.
Carpets look great, Chris.
08-06-2012, 08:14 PM
#6 | | Senior Member
I have an extractor but even that requires chemicals, on occasion. The trick, no matter what you use is HOT WATER or STEAM. I picked up an inexpensive steam cleaner from McCullouch that works most of the time.
Even that somtimes may not be good enough for some stains. In that case, Wolfgang Spot Remover is very good at taking those out.
I also use a nice interior detail brush from Mothers which I use to scrub the carpet clean.
Works for me. Amazon.com: McCulloch MC-1275 Heavy-Duty Steam Cleaner: Home & Kitchen |
08-06-2012, 08:34 PM
#7 | | Senior Member
| Re: Best OTC Carpet Combo Quote:
Originally Posted by kmsdetailing I have an extractor but even that requires chemicals, on occasion. The trick, no matter what you use is HOT WATER or STEAM. I picked up an inexpensive steam cleaner from McCullouch that works most of the time.
Works for me. Amazon.com: McCulloch MC-1275 Heavy-Duty Steam Cleaner: Home & Kitchen | I have two of those steamers that I got on sale and they work great! I agree, hot water or steam is the key for some of those tough, ground-in stains.
08-07-2012, 09:25 AM
#8 | | Member
Originally Posted by rdf When you use Tuff Stuff and/or Folex for this, using a Shop Vac or equivalent (ie not an extractor) to finish it off ... after the carpet dries completely ... if you were to dampen your hand and rub the carpet, would it feel soapy?
Thanks.
Carpets look great, Chris. | To be honest, I have no idea... I have considered using a fabric softener, as it can sometimes be left with a rough texture from air drying. As far as a soapy feel, it is possible being that I don't extract. I will let you know on the next detail I do (today)
__________________
Topher's Detailing
08-07-2012, 10:48 AM
#9 | | Member
Originally Posted by ChrisMessier To be honest, I have no idea... I have considered using a fabric softener, as it can sometimes be left with a rough texture from air drying. As far as a soapy feel, it is possible being that I don't extract. I will let you know on the next detail I do (today) | Thanks, Chris. I appreciate it. I hope this one turns out well for you, too. I have a friend who really needs (vehicle) carpets cleaned, and I'd like to try your method, but she had a bad experience with soapy residue and I don't want to repeat that.
Re the rough texture: I wonder if one of those pet hair removal brushes, the ones that have lots of slightly soft, flexible, rubbery cylinders sticking down, instead of actual bristles ... wonder if that'd help break up the rough texture?
08-07-2012, 11:30 PM
#10 | | Member
It could! I'm thinking it is relative to when bath towels are air-dried, and are left super rough to the touch. I may have to look into a rubber brush to solve this.
Also, it didn't feel soapy in the Fusion detail I performed earlier today. Granted, I took the advice here and added Simple Green 10:1 to the mix, which may have helped.
Let me know how it works for you though, the key is using stiff brushes.
__________________
Topher's Detailing
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » May 2013 | | S | M | T | W | T | F | S | | 28 | 29 | 30 |
| 1 | » Car Care Brands | | | |
