Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by Meghan
Sema Show 2008
433 photos
10 comments
» Autogeek Car Care Products
Dodo Juice Car Waxes
Reply
Thread Tools Display Modes
  #1
Old 08-10-2007, 03:41 AM
Question Confused
another newb questions.Beem reading about Menzerna line of products.Just out of curiosity,is Menzerna IP really a polish or more of a compound.Been reading about the IP,or is it just my ignorance about this product and this is what it says:
Based on its abilities you’d think it’s a compound but, in fact, Menzerna Intensive Polish is just what the name says – a polish on steroids
and
To call it a polish is somewhat misleading because it really falls somewhere between a strong swirl remover and a compound Even though the name says polish, by most standards,this is a compound.
So,can someone clarify which is which?
  #2
Old 08-10-2007, 10:12 PM
sparkie's Avatar
I think you answered your on question.
Polish can be abrasive and non-abrasive, polishes products may or may not have a chemical cleaner as part of it. They have less cut than compounds.
Compound is what I call the sandpaper abrasive. It has more cut than polishes. Use Compound only if all else has failed.
__________________
  #3
P1et's Avatar
24 HR Queue
I've heard quite a few people say to skip IP and just use SIP. That stuff apparantly is aggressive enough to get rid of defects, yet still finishes down to LSP...
  #4
Old 08-10-2007, 10:14 PM
Sevenrd's Avatar
Quote:
I agree with this. I never had much luck with IP or FPII. The pro line works much better for me.
  #5
Old 08-11-2007, 04:19 AM
TOGWT's Avatar
If you look up the Menzerna chart it will show cut/gloss/grit no removed,
I only use the por line but it will look something like this;
Product specific-Menzerna Polishes- are foam pad ‘dependant’ as far as its paint correction abilities are concerned and they appear to work better when the foam pad is ‘primed’ I would recommend a two level foam pad / polish system to really heighten the paints finish shine;
Power Gloss (POS 34A) will remove 1000 grit, cut 5.0 - gloss 1.5 (LC Foamed Wool, Yellow or Orange CCS foam pads)
Super Intensive Polish (PO83Q) will remove 2000 grit, cut 3.5 – gloss 3.0 (Orange LC CCS foam pads)
Final Polish (PO85U) cut 3.0 - gloss 4.0 (White LC CCS foam pad)
Nano Polish (105FF) will remove 2500 grit, for light surface marring and / or surface finishing, cut 2.5 - gloss 5.0 for LSP ready use a White LC CCS foam pad, these polishes can also be used for conventional clear coats
  #6
Old 08-11-2007, 09:28 AM
But SIP and IP have the same cut of 3.5 and grit of 2000.What make the 2 different then.Why do you prefer SIP and IP?
  #7
Old 08-11-2007, 10:24 AM
Or is it good enough to use 106ff and keep the SIP and IP as a last resorts. Please be patient with me .i`m still in the learning stage
  #8
Old 08-12-2007, 05:11 AM
Member
Quote:
I just did a 2000 chevy 1500.. used LC orange pad and 106ff. Let me tell you all the swrils and light scratches came right out. Honestly to me it seems like my poorboys ssr2.5 with a little more gloss. It wont pull out deep scratches but try it witha light cutting pad - you will be amazed! One thing i learned from AG thus far..use the least intense way first...
  #9
Old 08-14-2007, 10:42 AM
Darren F's Avatar
Would the Nano Polish be to agressive to use as a final polish on a Black Lexus? I am under the impression that the Menzerna line is more for harder clear coats not a softer paint like Lexus uses
__________________
Darren
  #10
Old 08-14-2007, 10:46 AM
D&D Auto Detailing's Avatar
SIP was created for ceramic clear coats.
__________________
D&D Auto Detailing
-Dan
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
confused about surf city orionz06 Auto Detailing Forum 10 08-27-2007 08:04 AM
still confused!!! shevie Auto Detailing University 4 10-11-2006 05:12 PM
Help !!!! Im So Confused Darren F Auto Detailing University 17 07-10-2006 06:13 PM
little confused BADZZHUMMER Porter Cable 7424 & Buffing Pad Forum 4 05-12-2006 09:23 PM
confused newbie gazzagolf Auto Detailing Forum 1 03-29-2006 03:13 PM
» December 2008
30 1 2 3 4 5 6
28 29 30 31 123
