Quote:
Originally Posted by budman3 Do you find that there are UV protectors in sealants? I'm a little confused because on DC you said that OCW contains UV absorbers and here I was thinking that was a spray wax and not a spray sealant. Is there a difference between UV protectors and absorbers? I'm not sure about the UV stuff but I personally don't believe any marketing for SPF in car care... |
When you see OCW after it has been sitting for awhile you'll notice it seperates. The liquid on the bottom of the bottle are the UV absorbers and they sink to the bottom because tghey weigh more than the other ingredients. Turn the bottle up side down and they al mix together.
OCW is a polymer/wax combo with UV absorbers added and uv absorbers, inhibitors or protectors pretty much mean the same thing.
As for sealants, OptiSeal has uv absorbers but I'm not sure if any others have them. It should be stated on the bottles as that would be an advantage to the end user. Like waxes though it can't be stated that a polymer product has "natural UV protection", it always has to be added.
Anthony
