05-28-2006, 11:30 PM
|  | Junior Member | | Join Date: May 2006 Location: Charleston, SC
| | | Best way to apply wax/sealant? Is there a proper technique for applying wax? I know this sounds like a newbie question...but here's the reason I ask.
I have always heard it is best to apply it in the same direction that water would drain off the vehicle. (Doors = apply downwards, Hood= apply towards front of vehicle). I also heard that this helps prevent swirls.
However, today when I was reading the Pinnacle detailing guide it said to use firm side to side motions when applying the Cleansing Lotion.
So long story short...is there a proper technique for applying wax?? Up/down or side to side or circular motion??
See ya on the road,
Matt
__________________
2002 Trans Am Firehawk. 345HP/345TQ Package.
Automatic with Zexel Torsen 3.23's, 1LE Suspension, SLP Performance Exhaust with Dual-Dual Tips, IROC Spoiler, Chrome 17x9 Firehawk wheels, Firehawk floor mats and cargo mat, black leather, T-tops. 22,060 MILES!!!
Moderator at www.Z28.com |
05-28-2006, 11:32 PM
|  | Senior Member | | Join Date: Mar 2006 Location: IL, Chicagoland
| | | The cleansing lotion is a little different. But you're right about the water draining.
When i get the Charger Supercharged... I'm going to race you.
__________________
*Signature removed by admin.
05-28-2006, 11:41 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Naples, Fl
| | | I'm intrigued. |
05-29-2006, 07:58 AM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | | I've always applied and removed wax one way only:
The direction that the wind would flow over the car.
So basically back to front. I also do this when I use my PC to lay wax down and remove.
Justin |
05-29-2006, 10:03 AM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | Quote: |
Originally Posted by justin30513 I've always applied and removed wax one way only:
Justin |
The circular motion can increase swirls. One direction as wind would travel across each panel is my preferred method of attack. I took right to it ... still occassionally need to remind the wife, as I do the same when washing, polishing, drying also. |
05-29-2006, 10:06 AM
| | | Ok so when applying and removing it, go front to rear instead of roof to tires?
See ya on the road,
Matt
__________________
07-06-2006, 10:33 AM
|  | Senior Member | | Join Date: Jul 2006 Location: Ft Lauderdale, Florida
| | | SO if you use an orbital buffer to apply and remove the wax you are going in a circular motion which is really not the best way to do it?
__________________
Darren
07-06-2006, 12:17 PM
| | Senior Member | | Join Date: Apr 2006
| | Quote: |
Originally Posted by Darren F SO if you use an orbital buffer to apply and remove the wax you are going in a circular motion which is really not the best way to do it? |
Unless your doing multiple cars and want to save time BUFF AWAY
But if its your own ride.......WHY? use a buffer?? todays wax's are so easy and fast......especially the WOWO waxs........ |
07-06-2006, 12:29 PM
| | | I thought the Orbital was the best way to do it..Is there a down side to using an Orbital?
__________________
Darren
07-06-2006, 02:53 PM
| | Senior Member | | Join Date: Apr 2006 Location: Boca Raton, FL
| | Quote: |
Originally Posted by Darren F I thought the Orbital was the best way to do it..Is there a down side to using an Orbital? | Are you talking about a Porter Cable Random Orbital or one of those cheapo orbitals at Autozone etc? I always apply sealent and wax by hand, EX-P and Natty's Blue are so easy to use plus there are certain spots you'd have to redo that the orbital missed.
Plus, especially on my suv, I'd have to use a lot more product on the PC to do so. Pointless, unless your a pro detailer doing multiple cars daily and time plays more of a factor. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| 1 | 2 | 3 | |
