Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Super Member agpatel's Avatar
    Apr 2006
    Greensboro, NC
    824
    Opti-Coat on Metal
    Has anyone used opti-coat on metal (Polished SS?) How did it work and any issues using it...looking to use it on my new exhaust tips to keep them clean and protected but dont know if it will really bond to metal well.
    Aug 2011
    The "OC"
    895
    Re: Opti-Coat on Metal
    I've used on metal and it bonds and works fine. However, a exhaust tip may get too hot for OC.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
    Sep 2011
    74
    I did my wheel and exhaust tips. seems to work well so far.
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by agpatel View Post
    Good metal-choice on the tips.
    Good question on SS/OC bonding!
    Hopefully the Good Dr./Chris will chime in; but here are a couple of my concerns about SS/OC bonding...
    -Does this mean that OC will have to 'penetrate' the protective oxide passive layer that surrounds/envelopes SS, that is formed: instantaneously...whenever SS is exposed to oxygen (atmospheric 'air')...
    If not: Would this oxide layer effect any of OC's 'Chemistry', or 'Characteristics'
    -Must OC, then, be applied to SS in a vacuum
    -If successful, in having OC bond to SS, will/would the protective oxide passive layer ever form again...If so, where.
    -Will OC's 'CC paint-film protective characteristics' provide a protective-layer, comparable to, and as protective as, SS's passive oxide layer
    -What is the "fracture-point" temperature of OC
    Just my curiosity...
    Apr 2006
    Greensboro, NC
    824
    I have some BF metal sealant which I have no problem using...but I also have some OC and well heck if I can use it I might as well. If it does not really bond to it because I know OC bonds to clear in a strong bond but dont know if that would happen with SS and would be no better then a regular traditional sealant.
    Aug 2010
    New Jersey
    15,159
    Quote Originally Posted by FUNX725 View Post
    Oh come on Bob--if it formed "instantaneously" no one would need to chemically passivate CRES. And what makes you think the OC has to penetrate rather than bonding on top of the passive layer?
    Dec 2010
    Ohio, USA
    21,057
    Are you saying that...After the chemical processes that has passivated CRES...that now what is called "SS" doesn't continue to passivate.
    Although my words selection: penetration/instantaneously...may not be the correct
    nomenclature....That really was part of my overall concerns/questions...And I see no harm in asking:
    -Who can honestly say, and actually know, if OC will bond with a chromium oxide passivation layer or not.
    Super Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,388
    I applied OC to my stainless steel sink and it didn't take. Reason unknown. I prepped it correctly.
    Optimum Guru Chris Thomas's Avatar
    Dec 2007
    Middle Tennessee
    1,824
    OC will bond to prepped metals including SS. However, if you use Optimum Metal Polish to prep, you will need to strip the surface afterwords to remove the sealant that's in it. Also, it will tolerate the heat from tips and brake rotors.
  10. #10
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by Chris@Optimum View Post
    Chris...Thanks for your informative response!
  1. Old, Original Opti-Coat vs. Newer Opti-Gloss vs. something else ??
    By Jed Clampett in forum Auto Detailing 101
    Last Post: 02-22-2017, 08:33 AM
  2. Replies: 12
    Last Post: 01-16-2014, 02:16 PM
  3. Replies: 11
    Last Post: 04-13-2012, 03:23 PM
  4. Opti-Coat/Opti-Guard and Poli-Seal Problem
    By gmck in forum Auto Detailing 101
    Last Post: 11-29-2011, 07:33 AM
  5. David F. Opti-Coat Test & What to do with Opti-Coat?
    By Old Tiger in forum New Car Care Products
    Last Post: 01-16-2010, 03:52 PM
