Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Free Bag with the purchase of a flex polisher
Reply
Thread Tools Display Modes
  #1
Old 03-18-2007, 02:29 PM
AUdakota's Avatar
How much product do you use?
About 3 weeks ago I polished my truck using XMT2 and than the XMT glaze. It feels like I used way too much product. I just looked and I used abour 25% of each of the bottles doing just one pass of each on my truck. With both products it felt like the liquid was drying up before the polish had completely broken down I would say 2-3 minutes max so I would add a little more to the pad and continue to work for another ~3 minutes or so. Does this sound right or was I doing too big of sections (about 4ftX4ft) or was I going too fast on the PC (btw 5&6) or should I just expect to buy more polish??
__________________
Frank
Thanks to AG I only wipe my butt with MF's now
  #2
Old 03-18-2007, 02:37 PM
abrcrombe's Avatar
I would say that is too much polish. Usually you want to start off working on 2ft x 2ft sections. Once you are more comfortable with using a PC, you can make it bigger. XMT does go into the pad a little more than other polishes, and when that happens you don't want to add more polish. You can just spritz the pad with some QD or water, and it should give you enough working time to let the polishes break down. Also, I don't know if the panels are hot when you are polishing. You want the panels to be cool when you polish, or else that will make the polishes dry even quicker. Hope this works for you.
  #3
Old 03-18-2007, 02:39 PM
I would say you are using too much product. try smaller sections and use less product. speed 6 is too fast for a glaze , I would use 4 , that works for me with a glaze. the big thing is too move slow with the PC especially when removing defects, let the polish breakdown. I like to keep the armspeed and PC moving around an inch per second when removing defects after you have the product spread around your work area on a lower speed. also make sure to overlap your path by 50% to ensure ample coverage. hope these ideas make sense to you.
  #4
Old 03-18-2007, 03:06 PM
AUdakota's Avatar
The surface was cool when I was working....
So this coming week I will try the following techniques when I work on some other cars:
Slow down movement
Use QD as pad "wetter" when product seems to dry up
Work smaller sections
slow glaze speed down.
__________________
Frank
  #5
Old 03-18-2007, 03:25 PM
orngez's Avatar
Slow down movement
definitely sounds like a better approach...just so you know as you get better with the product and its correcting times you will be able to work much larger areas...i believe it is justin on this forum posted a technique that i use as well but takes some time to learn and get used too...and product working time knowlege is a must....start at high speed and move slowly...and then when the product is about to fully breakdown and its working time is almost up slow the speed down and work a fast final pass...
  #6
Old 03-18-2007, 03:37 PM
ltoman's Avatar
Don't worry - you aren't the only one with a heavy hand!! Me too. And it is hard to fight. you know the if a little is good, more is better concept.
my son is doing it too.
__________________
Vette Princess ltoman
2007 Z51 Red Corvette ~ my baby
2006 Berry Red Saturn Relay ~hubby's baby
2001 Gold Saturn SW2 ~family beater
1998 Dk Green Metallic Plymouth Voyager Expresso ~ ebay mobile
  #7
Old 03-18-2007, 03:41 PM
nick19's Avatar
2 Nickel or 2 Dime sized amounts is all you need.
__________________
20 year olds rule!
"For each step-back, there is an equally or greater come-back..."
http://www.autogeekonline.net/forum/...must-read.html
http://www.autogeekonline.net/forum/...s-bluuuur.html
  #8
Old 03-18-2007, 04:08 PM
bambo2888's Avatar
you can either apply 3 x 2in. lines across your pad or a dime sized amount in the middle of the pad for each 2x2ft. area. 25% left means you used WAY too much. I did my car with probably about 3 applications for each 2x2ft. area and I still have more than you left...
__________________
Quote:
Originally Posted by TexasTB
"If you don't stand behind our troops, then why don't you stand in front of them"
2003 Yamaha R6
2000 Acura TL -- White Diamond Pearl
1999 Honda CBR600 F4 - Midnight Black Pearl
1996 Nissan Maxima -- Pebble Beige (RIP)
  #9
Old 03-18-2007, 04:11 PM
nick19's Avatar
I use two small dots because I work a larger area. Depends on the product your using as well; one or two small dots is all you need.
__________________
20 year olds rule!
  #10
Old 03-18-2007, 04:20 PM
AUdakota's Avatar
whoa baby I would just do a ring around the pad and that seemed like too little some times....
I bet the people at AG love me when I use 4x too much product hahaha
__________________
Frank
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Production car care products? lightning400hp Auto Detailing Forum 12 02-07-2008 06:16 PM
Product Review: Wolfgang Lens Cleaning System Pats300zx Auto Detailing Forum 8 10-06-2007 10:36 PM
A different kind of detailing, a new product used! Whitethunder46 Show N' Shine 18 01-02-2007 10:40 PM
Optimum coming out with new product... Meghan New Car Care Products 15 11-01-2006 09:44 PM
Meghan finally got Neothin to detail her SUV! Meghan Show N' Shine 19 05-20-2006 06:14 PM
» December 2008
30 1 2 3 4 5 6
28 29 30 31 123
