Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-04-2012, 07:26 AM   #1
Detail_Dude's Avatar
Gilmour Foam Master II - Settings?
I have the version of the Gilmour FM II gun with the brass sliding bar rather than the plastic dial. For those of you familiar with both versions, does sliding the brass bar all the way to the right produce the lowest mix ratio (equivalent to setting "A" on the plastic dial version) >> less foam? Also, is there a rhyme or reason to which setting to use or is it whatever fills my thrill?
My objective (right now) is to get good sudsy foam withut an overconcentrated solution that would tamper with my sealant & wax. In a month or so, I wil strip it all, but for now, taking it easy.
Detail_Dude is offline
Old 04-04-2012, 08:18 AM   #2
Setec Astronomy's Avatar
Re: Gilmour Foam Master II - Settings?
Quote:
That's just called the Foamaster.
Well...you don't want to push it all the way to the right with the little upright stop against the center piece. There are 5 settings (just like the II), but there are 6 holes in the spraybar, the one all the way on the left isn't drilled through and it's just for the detent ball to sit in. So what I usually do is push the bar all the way to the left, then start pushing it back to the right--the first hole it falls into is "E", then D, C, B, and A--which will be with the end of the bar a little distance away from the center housing.
EDIT--I think it's really a crummy design (I have 2) and if I ever have to get another one I'll get the II--looking at ABCD or E is a lot easier than counting holes and trying to remember in the spring which way it goes, etc.
My objective (right now) is to get good sudsy foam without an overconcentrated solution that would tamper with my sealant & wax.
I always try to concoct my settings and cup dilutions to acheive the concentration that the wash mfr. suggests, but I seem to be in the minority on this.
__________________
"Spray it like you mean it!"
Setec Astronomy is offline
Old 04-04-2012, 09:33 AM   #3
Now I know better. Thanks.
That is super helpful. I presume A produces the least foam and E the most. So, A wouls therefore result in a less diluted solution. No wonder why it last longer.
As you indicated, what a poor design from an end-user point of view. I do prefer, however brass to plastic.
Rebel! Kidding - much appreciated.
Old 04-04-2012, 09:58 AM   #4
I wasn't trying to be a jerk--just trying to be precise. The Foamaster II is very hard to find, I only know of one detailing store that sells it, and one internet bookseller...that's why I wound up with the regular Foamaster.
Yes, I believe that's right. As far as the dilution, if I'm using a wash that requres 1oz/gal, I mix 3:1 in the cup (3 water, one soap) and use the center hole (C, I guess) and that gives me 1oz/gal. Then if I want to richen it up or thin it out I can go two holes in either direction. That's for thick soaps that need to be diluted in order to draw properly up the tube; I've used thin soaps straight in the cup, which is nice because you don't have to refill very often (of course I then have to adjust to the smallest hole or "A").
Some people seem to use very high concentrations of soap in order to get more foaming or more cling...which I guess is ok if you are going to reapply LSP after...it's just a concentration I'd never use in a bucket. By the same token at another forum where we used to have a lot of foam gun discussions, it seemed that some people would use a very weak concentration in the cup. I'm not sure if they compensated by using "E" or if they just wind up putting a lot less soap on the car than I do.
__________________
Old 04-04-2012, 11:34 AM   #5
umi000's Avatar
I agree - I measure my soap and mix it in the soap container such that, using the middle setting (4 oz to 1 gallon), I get the same dilution on the panel that the manufacturer recommends. I then just adjust on the gun if I want it thinner or thicker - though like you, I never go beyond the next higher setting (6 oz to 1 gallon), since I'm worried about degrading my LSP.
__________________
Francis
umi000 is offline
Old 04-04-2012, 12:38 PM   #6
Thanks guys. I am getting it now. It is now becoming clearer that each setting A through E is +1.2 oz per gallon (A = 1.2 oz per gallon, B = 2.4 oz per gal, etc.), with E = 6oz per gallon.
THAT is good to know!
Old 04-04-2012, 12:44 PM   #7
The brass one is 1, 2, 4, 6, & 12 oz/gal...I thought the II was the same, but I can't find anything on it right now. Doesn't it say on the cup?
__________________
Old 04-04-2012, 12:53 PM   #8
Oops...my bad.
hmm....need to check later tonight. I know there is lettering onthe back, but it is kinda washed out for some reason.
Old 04-04-2012, 04:07 PM   #9
opie_7afe
Posts: n/a
imo i think the gilmour should be renamed to just gilmour soap dispenser gun, all it shoots out is sudsy water far from a good dwelling foam. don't even see the point in the gilmour as the suds don't even last long and dwell time sucks with it, id return it and buy a MTM hydro unit and adapter for around 65$ shipped....you wont get the foam you expect from these things that's why i refuse to buy one..all the soaps.water pressure and adjustments in the world wont make the gilmour do any sort of real dwelling foam...just my 2 cents.
Old 04-05-2012, 04:24 AM   #10
umi000's Avatar
I don't just use the Gilmour for a pre-foam
__________________
Francis
umi000 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Foam Cannon HP Foaming Lance for your Pressure Washer Dwayne New Car Care Products 42 09-22-2009 04:01 PM
Fun: Fuzion video and Foam Cannon HP Pics Emile Show N' Shine 10 08-17-2009 12:15 PM
Gotta admit, not too impressed with AG Foam Gun TCB Auto Detailing 101 24 07-11-2007 01:47 AM
Foamaster Foam Wash Gun Jason New Car Care Products 22 03-11-2006 07:31 AM
» May 2013
» Car Care Brands
