Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
23 comments
by admin
Exterior Gallery
55 photos
33 comments
by admin
Exterior Gallery
55 photos
33 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Metro Vac n Blo
Tags: ,
Reply
Thread Tools Display Modes
  #1
Old 01-04-2007, 11:33 PM
waxing and sealing
So im bored being stuck with the family.. i love them but still a week in a small condo with 6 people is alot of togther time.
so i was searching some forums (this and others I am a member of). I noticed one thread in which the person waxed and sealed withing minutes of each other (after the sealent was left on the paint to haze as sit).
I know many people wait for the sealent to sit and cure for 24 hours before applying the wax.
I am a wax man, as many of you know but i do apply a coat of sealent first to make sure the car is well protected.. just in case.
So i was wondering, how important is it to wait 12 to 24 hours for the sealent to cure before applying a coat of wax?
How many people wax right after sealning for personal or clients cars due to time or other restrants?
And finaly, what is the cure time on wax? i know it has been discussed but i always get a diffrent response, so hopefully i can get a more definte time frame, understanding that each wax is diffrent but im sure there is still a general time
Thank you for any info
-Mike
  #2
Old 01-04-2007, 11:44 PM
Kelso's Avatar
if you dont allow the sealant enough time to cure, you wont get te protection of the sealant.basically if it hasnt cured and you introduce a foreign substance(water, wax, etc...) i guess it removes that sealant you just applied.
on the flipside i know zaino has an additivie to make their sealant flash cure. i dont know how it works, or if it works as ive never used the zaino line personally
  #3
Old 01-04-2007, 11:45 PM
supercharged's Avatar
It is necessary for sealant to cure for 12-24 hours, otherwise polymers will drown, and protection will fail.
__________________
1997 Acura 3.2 TL (sold)
  #4
I'd let the sealant cure first before apply wax. Some people don't but the sealant obviously has to set and cross link so I wouldn't applying anything over till it cures. I tried once and ended up with a little smearing.
__________________
The real WyStang:
  #5
Old 01-04-2007, 11:57 PM
nick19's Avatar
Try the "SWIPE TEST" for wax...
The swipe test is where you take your clean finger, and swipe it briskly across the finish with the wax on it. If the paint is clear, without residue where your finger made the swipe, the wax is ready to wipe-off. If the area you have swiped is smudgy, or streaky, or there is noticeable wax in the swipe area, then the wax has not set-up long enough and you should allow more time for the wax to set-up before your remove it.
If you remove it before it has set-up, you will risk removing too much of the wax from the surface and thus leave less than engineered to remain behind on the finish.
  #6
Old 01-05-2007, 12:03 AM
thnkx for the info nick, but i dont mean how to know when to remove. Im just wondering how important the cure time (not the dry time is). I am an avid waxer, so i have lots of experience.
People, and sealents talk about waiting 12-24 hours before another coat of wax to allow the sealent to "cure" (again diffrent from dry time).
but thank you, the swipe test is good info, anyone learning to wax should learn it, i learned it when i fisrt started and it has come in handy on a few waxes
  #7
Old 01-05-2007, 12:05 AM
Whitethunder46's Avatar
I don't think you quite understood the question. Sealants usually need 12-24 hours to settle into the paint and "cure" This doesn't have anything to do with wiping off, but rather a chemical change. I believe oxygen is the key reason why sealants need to cure.
  #8
Old 01-05-2007, 12:06 AM
nick19's Avatar
The later the better.. 12-24 hours or more is "typical", just like the Sealant. You can do one coat after another.......but...... I wouldn't.
  #9
Old 01-05-2007, 12:08 AM
nick19's Avatar
Quote:
He also asked about waxes too.... I'm tired, although no excuse..
Quote from above ^
"And finaly, what is the cure time on wax?"
  #10
Old 01-05-2007, 12:16 AM
Quote from above ^
hehe i undertand the tired (i have just enough energy to make a banana dance)
With a wax it has a dry time and a cure time.
The dry time is what you are talking about, it which you can do the swipe test on.
wax however has atime to fully dry or cure, similar to a paint, you paint the wall, it dries but still need to sit a day to cure.
I was just wondernig what the cure time it, if you wax before the cure time it just combines with the previous layer and makes the new wax pointless.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
polishing fresh paint k20z3kid Auto Detailing Forum 19 07-18-2007 11:20 PM
QD to much? roadrunner1659 Auto Detailing Forum 33 07-06-2007 08:11 AM
Door Jams kastanaras Auto Detailing Forum 21 04-10-2007 02:19 PM
STOP !! Picture Time .... Souveran Only ! killrwheels@autogeek Pinnacle Wax 93 03-02-2007 11:18 PM
What in the swirl can I do? Waxing tips. Silver Fox Auto Detailing Forum 4 08-29-2006 03:22 PM
» December 2008
30 1 2 3 4 5 6
28 29 30 31 123
