I thought I'd post a couple of rotary mistakes for Auto Geeker's and some of the chip filling tools I use on BMW's.
1st Mistake: Did not use a paint guage on the edge and it was thin. Plus, I mis-used the rotary by polishing from the high spot on the hood and swept down to the recess...big no-no. The owner showed me that the best way is polish the flat on the high edge, then start from another direction and work up to the high edge.
2nd Mistake: Tried to polish the lower edge of the trunk lid and the rotary backing plate caught the plastic bumper cover...melted faster than I could react.
On to filling chips. The tools I use are: used syringes (I'm diabetic and have a never-ending supply), touch up paint, an edged rubber squeege. I apply a small amount of touch up with the syringe, squeege the excess to fill the chip and let it sit for 5 minutes. Then, I have a solution of solvent + linseed oil and gently remove the smear. If the chip is deep enough, I keep adding until the chip is filled to the max.
Tools:
Here you can see the smeared portion that must be removed with the solution. Doesn't take much effort, only good lighting and time.
Toto
