car wax, car care and auto detailing forumAutogeekonline autogeekonline car wax, car care and auto detailing forum HomeForumBlogAutogeek.net StoreCars WallpaperLink To UsvBGarageGalleryDetailing How ToFollow us onTwitterFacebook
Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
» Official Detail Fest 2010 Information Thread!!
» Current Poll
How do you prefer your information?
Paper Handbook - 30.14%
22 Votes
DVD - 15.07%
11 Votes
Digital PDF Download - 54.79%
40 Votes
Total Votes: 73
You may not vote on this poll.
Reply
Thread Tools Display Modes
Old 08-15-2009, 12:19 AM   #1
Buckskincolt's Avatar
Exclamation Best Polishes to use under Zaino?...HELP!
Hello,
I'm reading that some polishes don't work well under polymer sealants like Zaino Z2 and Z5? So what line of polishes are going to give me the least trouble and not effect the durability and clarity of the Zaino products? I currently have Have the Menzerna IP PO91E and the FP PO85U (Menzerna intro kit) on order. Do you think I will be OK or will I need to clean off the residue with something before applying the Zaino products to avoid cloudiness and durability issues? If this is not a good choice to use under Zaino what is? I can return them before use and get different products if there is a better match. Maybe the PB line? OK I'm all ears!
Wow, I just want to take care of my cars and now I find I need to be a chemist to do it!
Buckskincolt is offline
Old 08-15-2009, 05:33 AM   #2
rwisejr's Avatar
Re: Best Polishes to use under Zaino?...HELP!
I have used Menzera,Optimum ,Meguiars polishes with no problems under Zaino.You should always do an IPA wipe down to make sure all of the polishes oils are removed from the paint before any sealant application. Plus wiyh Zaino I always liked to give it a good base so I always used the ZAIO .Which is a very good paint cleaner.Then you will have no issues
__________________
Flex3401,Makita ,Flex3403,603VV and Metabo Rotarys,PC 7336,UDM,PC 7424XP, Aztec Hot Rod, CamSpray 1500A and CamSpray Foam cannon.
Ron !!!!!
rwisejr is online now
Old 08-15-2009, 07:03 AM   #3
Why not use one of the Zaino prep products?
While not absolutely necessary, using Z-PC or Z-AIO should eliminate any question of compatibility.
(Kind of like Ron said. I didn't read his post.)
__________________
Charles
The Rainmaker
CharlesW is offline
Old 08-15-2009, 08:43 AM   #4
Wow, thanks for the quick replys guys!
Quote:
Originally Posted by rwisejr View Post
I have used Menzera,Optimum ,Meguiars polishes with no problems under Zaino.You should always do an IPA wipe down to make sure all of the polishes oils are removed from the paint before any sealant application. Plus with Zaino I always liked to give it a good base so I always used the ZAIO .Which is a very good paint cleaner.Then you will have no issues
OK Thank you. I just need to get used to a IPA wipe no matter which polishes I use. That's simple enough. I do use the ZAIO as a base for Z2 & Z5 so I'm on target with that. Thank You rwisejr, I'm brand new at all this and appreciate your help.
Charles, Z-PC and Z-AIO I have used but I'm looking for more correction. My mom has a 2003 Tahoe that has never been even waxed and looks pretty sad. I needed some more aggressive polishes than what Z offers. Z doesn't even recommend random orbital application for his products and I'm not tough enough to take this on by hand. LOL
I will follow your advice to use the ZAIO after any polishes I use. Thanks for your feedback!
Old 08-15-2009, 08:18 PM   #5
Moderator
killrwheels@autogeek's Avatar
Menzerna works well with Zaino .. never had any compatibility problems with Menzerna with any wax or sealant.
killrwheels@autogeek is online now
Old 08-15-2009, 08:28 PM   #6
Quote:
I'm not a Zaino fan, but this information is from the Zaino site:
(Note #3 and the tip for more bite.)
APPLICATION INSTRUCTIONS
Note: For best results, use on a cool surface, out of direct sunlight. Product may be used in the sun or on a hot surface, but more dusting and minor streaking may occur.
  1. Wash and dry your vehicle as normal.
  2. For HAND use: apply a small amount of Zaino Z-PC Fusion to a cotton or foam applicator pad (draw an "X" from corner-to corner of your pad). Work a small area (no bigger than 2' x 2') with the Zaino Fusion, using firm motions. Work the product for as long as necessary - stop to occasionally check your progress. Circular motions may be used, but always finish with front-to-back or up-and-down motions. When satisfied with progress, continue to step 4.
  3. For MACHINE use: Can be used by random orbital or (for experienced users) rotary. Select a moderate speed (RO - 4.5; Rotary - 1200rpm) and an appropriate cutting or polishing pad. Apply Zaino Z-PC Fusion to the buffer pad in a "star" pattern. Start machine slowly to reduce sling. Work a small (2' x 2') area with moderate pressure until satisfied with results.
  4. Buff the area clean with a soft, lint-free, non-marring towel. If satisfied with the results, proceed to next section. If more buffing is required, repeat either step 2 or 3. Problem areas like door handles (where keys often scratch) may require a few applications for best results.
  5. When done, apply either: Zaino ZFX enabled Z-2 PRO, Z-3, or Z-5 to the surface for a long lasting, great looking shine that will lock-in the results of your work with Zaino Z-PC Fusion.
Tip: If more "bite" is desired, you can mist a slight amount of clean water (from a spray bottle) while using Z-PC Fusion. The water will interfere with the buffers that encapsulate the abrasives and will produce a slightly stronger result. Water can also be used to minimize dusting when using a machine buffer (random orbital or rotary).
__________________
Charles
The Rainmaker
CharlesW is offline
Old 08-15-2009, 10:34 PM   #7
Quote:
Killr, are you saying I can Skip the IPA wipe down and be just fine? That would be nice if that's the case. Thanks!
Thanks Charles, I guess I some how missed that....I thought I had read the entire site at least three times LOL. I'll need to try the water trick and see what that does.
I really like the Zaino products because they hold up really well against the salt here in the Pacific NW. I live right on the beach and Oregon winters can be tough on paint and we don't get much of a chance to re detail in the winter, so most nuba waxes are out for me.
I like the look of Zaino as well. I must say I'm always open to suggestions to products who people think perform better. I've tried the Klasse AIO and did not like the 24hr time to dry here in the humid weather. It really did not buff off all that easy either. I know it's supposed to be a great product but it didn't work to well for me....And it just could be me too!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Menzerna Polishes - Methodology Part I TOGWT Tricks, Tips and Techniques 34 04-27-2009 01:09 PM
REVIEWS - Wolfgang 3.0 Polishes + a few others makdaddy626 Auto Detailing 101 11 04-08-2008 04:51 PM
How long do you guys work in your polishes? Thejoyofdriving Auto Detailing University 26 09-21-2007 06:48 PM
Poly charger in Zaino Z6 over Zaino clear seal nc_yella Show N' Shine 10 04-23-2007 02:48 PM
05 Ford Expedition - a Zaino Detail Frugle Show N' Shine 48 10-31-2006 10:53 PM
» March 2010
28 1 2 3 4 5 6
28 29 30 31 123
» Car Care Brands
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
