Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
» Autogeek Car Care Products
Tags: , ,
Reply
Thread Tools Display Modes
  #1
Old 06-25-2008, 06:31 PM
Member
DIY: Headlight Lens Restoration
DISCLAIMER:
Wetsanding and Powertools should not be exercised on a vehicle by ANYONE but a professional. WORK AT YOUR OWN RISK
Okay, this seems to be a common problem with MK4 Jetta headlights I've noticed. The lens begins to fog up with road debris, fallout, and surface marring which really cuts down on night vision. There is a fix though and this is it.
Tools needed:
800 grit sand paper
1000 grit sand paper
1500 grit sand paper
Some sort of wet-sanding liquid (water, instant detailer, a light degreaser)
Cutting Compound of your choice
Polishing Compound of your choice
Optional tools:
Machine buffer, Rotary, or DA with pads (I used a PC7424 with 2 different levels of CCS pads)... Power tools will cut down on work time/effort required by exponential amounts
Various assortments of Torque (T25, T27) if you will be removing the headlights/bumper-cover
Some sort of paper-tape if not removing the headlights/bumper-cover
Here is a close up in detail of a lens that needs restoration. (this car only has 50,xxx miles but the headlights are subpar)
Step one: If removing the headlight is not an option, be sure to tape around the lens to protect the paint on the vehicle (we will be sanding). Save yourself some time and effort by taking this step
Step Two:
Begin wetsanding the headlights using the most course grit first (i started with 1000 grit but 800 grit would have been better). Be sure to go in a back in forth or up and down motion, DO NOT MAKE CIRCLES!
Step Three:
Progressively move towards a finer grit of sand paper until you've reached the finest grit you have (I finished with 1500). The headlights will begin to haze over. DO NOT BE ALARMED, this is good. We will buff that out later
Step Four:
Use a rubbing compound to slim down on the scratches/haze that have developed as a result of wetsanding. Again, go back and forth, DO NOT MAKE CIRCLES. (I used a PC7424 with Lake Country CCS pads (yellow and orange) and Pinnacle XMT#4)
Step Five:
Use a polishing compound to get the finished look. (I used the PC7424 with a Lake Country White CCS and 3M Finnesse-IT2 Finishing Polish)
(I opted to remove the headlights from the vehicle as I was not acheiving the results I desired while the lights were installed on the vehicle. The front bumper cover must be removed before you can remove the headlights)
Before and After:
After Pictures
After a bath and ready for customer delivery
Happy Detailing
-Dan
  #2
Old 06-25-2008, 07:13 PM
killrwheels@autogeek's Avatar
Moderator
Re: DIY: Headlight Lens Restoration
not to knock your hard work, but I used the Wolfgang Kit a couple years back on friends Malibu and got similar results quite a bit quicker. He actually took the kit when done he liked it so much. It had a foam drill bit and some polishes and sealants.
nice work on yours too ...
  #3
Old 06-25-2008, 07:55 PM
budman3's Avatar
Have you ever used some sort of coating or protectant after polishing to prevent the oxidation from coming back?
  #4
Old 06-26-2008, 03:19 PM
in the first pictures I was praying the car was going to get cleaned too...haha
nice work on the headlights...
__________________
~Dom
  #5
Old 06-26-2008, 11:59 PM
f_bomb's Avatar
Member
I've tried a lot of DIY methods...Toothpaste, wax, PlasticX, brasso. I heard used brake fluid works but wasn't bold enough to try that...Picked up Quixx restore kit at a local shop after reading good reviews in a Nissan mag. The wax did a good job (best so far),they suggest wetsand too and have a little kit w/it.
I will dig this up when I do (the wet sand)...Looks good- minus the bird turd!
  #6
Old 06-27-2008, 06:27 AM
rwisejr's Avatar
Nice turn out .But I usually use 1000 Grit and system one X3 and the system one 4 inch pad and have the same results and less time consuming.Not to knock your process !!!
__________________
Club Flex Member ;Club SystemoneMember
Ron !!!!!
  #7
Old 07-13-2008, 08:36 PM
I use a slightly modified technique. I wet sand with 1500 - 2000, then use my rotary with a 4 " PFW and Megs 95 or 85/84 if you have that.
  #8
Old 07-13-2008, 11:59 PM
Jimmie's Avatar
Just finished some on a Honda. 2000grit; compound w/5.5 orange, rotary; XMT 1 w/5.5 white, rotary; Klasse AIO hand app. Perfect.
  #9
Old 07-14-2008, 02:40 PM
ss-truck's Avatar
I know depending on severity of hazing and how long to repair , but what is the average price you guys charge for polishing the lenses ?
__________________
Mike Williamson
1971 Buick GSX Stage 1
1967 Buick GS 400
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Cobra headlight restoration matt@autogeek.net Show N' Shine 3 05-26-2008 07:45 PM
Headlight Restoration buster Auto Detailing University 8 03-24-2008 08:41 AM
Headlight Restoration 01vw18t Auto Detailing University 6 12-21-2007 07:47 AM
Headlight Lens Restoration: Wolfgang or Diamondite KG21 Auto Detailing Forum 5 10-27-2007 10:12 PM
Headlight Lens Cleaner NissanOwner Auto Detailing Forum 5 04-26-2007 07:23 PM
» October 2008
