Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
by admin
531 photos
16 comments
» Autogeek Car Care Products
Our car care cleaning kits are thoughtfully assembled by expert car care professionals
Reply
Thread Tools Display Modes
  #1
Old 06-20-2008, 08:01 PM
pricha00's Avatar
Best polish for hard CC??
A friend has a race car that was painted by a hot rod painter who uses House of Kolor products exclusively. Paint is five years old or so and was polished when first shot but only washed using a QD ever since. The car is either in a trailer or a garage 99% of the time anyways so washing is kind of useless and drag cars aren't exactly sealed against water anyways. I was attempting to remove some moderate scratches on the fenders from leaning over the car to do engine maintenance. I started with XMT 3 on a orange cutting pad at speed 6 on a UDM. No luck. It seemed to get some real fine blemishes out but no improvement on the major issues. Then I got gutsy and tried Optimum compound on a yellow cutting pad using the same technique but still similar results. I would be scared to try that combo on my 06 Toyota but the owner said give it a shot so I did. Better but not as nice as I would like. My question is what is the most aggressive polish I should try on this clear? The painter took like a whole day with a rotary to polish it five years ago and even he commented on the hardness of the CC. Should I be investing in some Menzerna product? Is there really a huge difference between the Intensive Polish and the Super Intensive Polish?
Pat.
__________________
2006 Black Rav4.
Makita 9227C, UDM, Optimum polishes, Pinnacle XMT polishes, Poorboy's Sealant, Collnite Insulator wax, various 4,6.5,and 8 inch pads. Microfiber towels galore. And a big thanks to Meghan for shipping to Walt Disney World.
  #2
Old 06-20-2008, 09:13 PM
bryansbestwax's Avatar
Re: Best polish for hard CC??
SIP is made for ceramic clear coats and other hard clear surfaces. It can be used for all but maybe a little on the agressive side for average paint. Nano is the finishing polish for hard clear coats, a must for darker paints
  #3
Old 06-20-2008, 09:43 PM
I've seen lots of good results with Optimum Compound.
__________________
AJ Auto Detail, LLC
  #4
Old 06-21-2008, 01:12 AM
pampos's Avatar
Menzerna RD3.02 works OK for me....
__________________
PERFECTION OF REFLECTION
  #5
Old 06-21-2008, 03:24 AM
TOGWT's Avatar
a)The use of a duel level foam pad (primary / secondary) / single polish correction system; will change the way each polish works in accordance to which pad you use (i.e. use a polishing pad followed by a finishing pad) and will really heighten the paint finish shine.
b) For most paint correction use *PO 106 FA / 106 FF a Lake County (LC) White or Orange and PO 85 D3.01 polish with a (LC) Blue foam pad at 1000 RPM should be all you need.
c) For paint renovation use PO S34A Power Gloss (LC Purple wool pad 1500 – 1800 RPM).
It has a short work time slow cut and tends to ‘dust’
Always be aware of the implications (paint removal) of using highly abrasive compounds as they can remove a significant amount of paint.
USA Part numbersEuropean Part numbers
PO83Q (*Super Intensive Polish) PO85RD3.01 /2 (Europe version)
PO91E (*Intensive Polish) PO85RD3.02 (best overall lustre wetness, clarity and gloss)
PO85U (Final Polish)
Notes –
a)*Finishing polishes were formulated for Ceramiclear paints, the micro diminishing abrasives are milled finer and much harder, and also contain a higher abrasive content, 7% whereas the other polishes contain 3% abrasives.
Alternatve polishes - 3M™ Perfect-It™ 3000 Extra Cut Rubbing Compound, 06060
3M™ Perfect-It™ 3000 Ultrafina™ SE (US) 06068 / Ultrafina SE (UK) 50383Use the ‘Slow Hand’ method for application;White polishing (softer less dense foam (70 PPI) with a light abrasive cutting action) followed by a Blue or Black Final finishing (100 PPI) LC CCS foam pad at 1100 RPM
  #6
Old 06-21-2008, 07:15 AM
killrwheels@autogeek's Avatar
Moderator
SIP came to my mind also ... aggressive at first but breaks down quite quickly.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Menzerna Polishes - Methodology Part I TOGWT Auto Detailing Forum 25 01-07-2008 02:18 AM
Question About PB Pro Polish & PWS Reddwarf Auto Detailing University 7 01-05-2008 11:46 PM
Menzerna Nano Polish PO106FF vs. Final Polish PO85RD Meghan Auto Detailing University 45 10-12-2007 01:21 AM
Can we post more details? Black Diamond Auto Detailing University 17 04-21-2007 01:22 AM
New Product Abbreviation Chart sparkie Auto Detailing University 4 11-09-2006 05:24 PM
» October 2008
