Go Back   Auto Geek Car Care, Car Wax and Auto Detailing Forum > Auto Detailing Forums > Auto Detailing University
Featured Photos
by admin
531 photos
0 comments
by admin
531 photos
0 comments
by admin
531 photos
0 comments
by admin
531 photos
0 comments
» Autogeek Car Care Products
Our car care cleaning kits are thoughtfully assembled by expert car care professionals
Reply
Thread Tools Display Modes
  #1
Old 04-23-2008, 07:17 AM
Rotary tips
I just got my Makita and done plenty of research. I've been practicing on my DD F-150 and on low speeds, the Makita does more paint correction than a PC ever could.
I know the basics, keep the speed low, never stop and all keep moving, pay attention to the 12-3 area and keep the pad tilted slightly. I've started with just a white polishing pad and low speed.
What am I missing?
I plan to use Foam Pads for now, which wool pads are more user friendly?
__________________
  #2
Old 04-23-2008, 08:32 AM
TOGWT's Avatar
Re: Rotary tips
Rotary Usage Tips- http://www.detailingbliss.com/forum/f12/rotary-usage-tips-1212.html
Read up on rotary polishers and pads here:http://www.autogeek.net/circular-polishers.html
  #3
Old 04-23-2008, 08:37 AM
t-bone's Avatar
Member
Re: Rotary tips
I am new to the rotary myself and have done 2 full correction jobs with my makita. I am using the system one with the wool/foam combo and have found it to be a very good setup for a beginner such as myself. Wool is very forgiving as best I can tell because I could work a 2x2 area for a while and the paint would barely be warm to the touch but I would get awesome correction and on a light colored car could almost be LSP ready. This is all coming from a amature detailer so take it as lightly as you wish.
  #4
Old 04-23-2008, 08:50 AM
Member
Re: Rotary tips
I am new to a rotary also, i have a Milwaukee Rotary. My question is, do you have to work the polish in before breaking it down, as you do with a Porter Cable?
  #5
Old 04-23-2008, 12:23 PM
TOGWT's Avatar
Re: Rotary tips
Diminishing Abrasives
Diminishing abrasives require friction, to activate and progressively reduce there size until they become a finite milled dust; they are buffered or cushioned in a lubricating water-based oil film emulsion, usually in a semi-liquid paste. Wet polishes eliminate the heat caused by buffing; heat causes gloss loss.Some very abrasive compound polishes don’t feel abrasive to the touch because the particles are formulated in a solvent or polymer oils in a water-based emulsion and are not released without friction.
The abrasive start off as large particles, which removes the most paint, they are then reduced in size into finer and finer particles, removing progressively less of the paint surface, by the friction caused by the foam pads contact with the paint surface. By varying the size of the abrasive a differing cut is obtained, so the more the abrasives are reduced in size the finer the resultant finish until the particles are reduced to a very fine powder, which in turn produces a burnished surface shine.
- http://www.detailingbliss.com/forum/f37/how-can-i-tell-when-polish-3100.html#post49743
  #6
Old 04-24-2008, 08:11 AM
Re: Rotary tips
Quote:
Originally Posted by TOGWT View Post
Exactly what I was looking for
Autopia had some great info as well.
thanks for the tips!
__________________
  #7
Old 04-24-2008, 08:25 AM
David Fermani's Avatar
Re: Rotary tips
I would avoid tilting your pad when you're buffing (especially a flat surface). The flatter the better or you'll get uneven pressure of the pad to surface contact.
  #8
Old 04-24-2008, 08:32 AM
Meghan's Avatar
Moderator
Re: Rotary tips
Quote:
Titling the pad scares me! When I use a rotary and I try not to very often! I keep the pads flat, just because I am not a pro with a rotary and do not want to burn a spot.
  #9
Old 04-24-2008, 01:38 PM
Re: Rotary tips
Quote:
Originally Posted by zaxjax View Post
... and keep the pad tilted slightly.
Keep the pad flat.
  #10
Old 04-24-2008, 02:17 PM
bryansbestwax's Avatar
Re: Rotary tips
Quote:
Originally Posted by ZoranC View Post
Keep the pad flat.
Agree
only tilt the pad to get into grooves or valleys
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
My first attempt with Rotary - 35 Ford dennish Show N' Shine 8 07-10-2007 10:58 AM
Pat vs The Rotary Pats300zx Auto Detailing Forum 11 07-05-2007 10:01 AM
Ford P100, rotary play Truls Show N' Shine 10 06-04-2007 12:58 PM
What Is The Best Rotary?!?!?! scottgt Auto Detailing Forum 19 05-14-2007 02:35 AM
Which pad textures are most common for the rotary? Avengeance Auto Detailing Forum 12 11-03-2006 12:11 AM
» August 2008
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
