04-05-2008, 06:13 PM
| | Member | | Join Date: Feb 2008
| | | Cloudy Instrument Panel That clear plastic over my instrument panel has some cloudy spots. What can I use to get them out and restore it?
I think I used a cleaner or dressng on a towel and got too close to the panel. The cloudiness is along the bottom right and right edges. There are also a couple of lines that look like miniature drips where I was probably spraying onto a towel and a droplet wafted onto the plastic. I don't know when it happened or what I might have been using. I'm even considering that It was like that when I bought it in Jan., and there was some kind of protectant covering up the cloudiness. I only just noticed it today for the first time when I used DP Total Int. Cleaner on it, and I don't think that is what caused it.
Any suggestions? Please help. It bugs the hell out of me... |
04-05-2008, 06:15 PM
| | | Re: Cloudy Instrument Panel Oh btw, I have Klasse Cleaner/Protectant. Is that safe to use on the clear plastic, or will it give me more problems? |
04-05-2008, 06:30 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Re: Cloudy Instrument Panel Plexus might work also ... |
04-05-2008, 08:05 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Naples, Fl
| | | Re: Cloudy Instrument Panel |
04-05-2008, 08:14 PM
| | | Re: Cloudy Instrument Panel Mother's Plastic Polish... Would that be anything like Meg's PlastX?? I have some Meg's on hand!
Plexus... Would that really polish out the haze or is it more of a protectant? How does it compare to DP Plex-All? And can you use Plex-All on tint like Plexus? |
04-05-2008, 08:29 PM
| | | Re: Cloudy Instrument Panel Okay, I just read the product descriptions for both of the Mother's and Meg's products. It looks like I will give the Meg's a try since I have it on hand. Thanks for the suggestion, I forgot I had it and the bottle doesn't say anything about instrument panels (although the webshop does) so I would have ruled it out.
I will also throw a bottle of either Plexus or Plex-All in my cart for future cleaning and protection needs. If anyone can chime in with comparisons or info on Plex-All on tint that would be great.
Thanks so much for your feedback guys. I feel better all ready! |
04-05-2008, 08:38 PM
|  | Senior Member | | Join Date: Mar 2006 Location: AR
| | | Re: Cloudy Instrument Panel plexus is a great product. haven't used it to remove severe scratches in plastic. I tend to use other plastic polishes such as meqs, novus, etc.
after you correct the plastic, plexus and a very fluffy, clean MF should be used to clean the area. |
04-06-2008, 06:29 AM
|  | Senior Member | | Join Date: Jun 2007 Location: Raleigh, NC
| | | Re: Cloudy Instrument Panel Quote:
Originally Posted by :::houseofbunny::: Okay, I just read the product descriptions for both of the Mother's and Meg's products. It looks like I will give the Meg's a try since I have it on hand. Thanks for the suggestion, I forgot I had it and the bottle doesn't say anything about instrument panels (although the webshop does) so I would have ruled it out.
Thanks so much for your feedback guys. I feel better all ready! | Meg's PlastX is more aggressive than Mothers. Meg's is good for correction like on headlights but it will leave a slight haze that is especially noticeable off axis on sensitive optical surfaces.
You will need to finish with something like Mothers (Meg's makes a milder polish called #17?) to really get it clear. This is less important on headlights but you can notice it on an instrument cluster plastic.
__________________
Al
04-06-2008, 07:54 AM
|  | Moderator | | Join Date: Mar 2006 Location: Florida
| | | Re: Cloudy Instrument Panel DP Plex All, or Plexus will get it mixed for you. |
04-06-2008, 05:44 PM
| | | Re: Cloudy Instrument Panel "Meg's PlastX is more aggressive than Mothers. Meg's is good for correction like on headlights but it will leave a slight haze "
I went ahead and tried the PlastX. I didn't notice any marring, but PlastX leaves a protective film that may be covering that up. It did a pretty good job and removed maybe 80% of the problem. What remains is evidently deeper damage, but I am pretty happy with how it came out. You would really have to look hard from a particular angle in the right light in order to see anything.
Thanks Megan, I am going to give the Plex-All a try. I'm liking the DP line. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » September 2008 | | S | M | T | W | T | F | S | | 31 |
| 1 | 2 | 3 | 4 | |
