» Official Detail Fest 2010 Information Thread!! | |  | |
12-31-2007, 06:20 PM
#1 | | Senior Member
| Working with ONLY a PC or UDM? How long?
Hey guys,
I keep looking at the show and shines and from what I've seen, a lot of you only use a DA (pc7424 or UDM) as your tool to polish. Answer me honestly, doesn't that take a LONG time and it's very physically draining?
__________________ AP Auto Detailing & Car Care "Care, Pride, Passion" Serving the Greater Toronto Area 24/7, 365.
Direct e-mail: info@apautodetailing.ca |
12-31-2007, 07:54 PM
#2 | | Member
| Re: Working with ONLY a PC or UDM? How long?
It is very time consuming to polish with one of the DAs you mentioned. However I can not even imagine how long it would take to polish by hand and do a good job. So to answer your question, yes, it is very physically draining but it at least makes polishing a bearable step in the detailing process.
01-01-2008, 01:20 AM
#3 | | Senior Member
It takes along time with a pc ,i polished for 3 hours on sat.that was just 1 pass!
__________________
Detailed Reflections |
01-01-2008, 01:34 AM
#4 | | Senior Member
Mixxer what do you mean by one pass? one type of polish? then you use a finish polish?
I like the PC7424 because its much more user friendly. If you detail for a living then I am sure there are better options.
__________________ 98 Z/28 |
01-01-2008, 06:57 AM
#5 | | Member
| Re: Working with ONLY a PC or UDM? How long? Quote:
Originally Posted by The Skillmaster It is very time consuming to polish with one of the DAs you mentioned. However I can not even imagine how long it would take to polish by hand and do a good job. So to answer your question, yes, it is very physically draining but it at least makes polishing a bearable step in the detailing process. |  i normally took at least 6hrs for full polishing with the UDM (cutting, polishing, glossing, and wax) , the result was great but time very consuming anyway.
I also question if Flex 3401 can do the better job, perfect result and spend a liltle time if compare with PC & UDM?
01-01-2008, 08:12 PM
#6 | | Senior Member
it's been compared, the flex is almost 2x faster just because it CORRECTS faster, i'd use a UDM or PC to apply wax or sealant because its lighter and it can spread faster.
01-02-2008, 01:11 AM
#7 | | Senior Member
It takes an EXTREMELY long time when you do it right. Thank god for the rotary.
01-02-2008, 03:29 AM
#8 | | Senior Member
Originally Posted by m4gician Hey guys,
I keep looking at the show and shines and from what I've seen, a lot of you only use a DA (pc7424 or UDM) as your tool to polish. Answer me honestly, doesn't that take a LONG time and it's very physically draining? | ever wonder why a demand for the new Flex polisher is so high??? It's UDM on steroids!!! Almost as powerfuls as rotary (well, pretty close)...
__________________
1997 Acura 3.2 TL (sold)
01-02-2008, 10:15 AM
#9 | | Senior Member
Originally Posted by lethalxls1 Mixxer what do you mean by one pass? one type of polish? then you use a finish polish?
I like the PC7424 because its much more user friendly. If you detail for a living then I am sure there are better options. | If you detail for a living, you almost have to use a rotary.
01-02-2008, 10:18 AM
#10 | | Senior Member
Correct!
The reason the Flex is so popular is the time factor. It allows you to cut the time it would normally take with the PC in half or less. This machine still requires care and safety, it can do some damage too. It's pretty strong and can handle you barring down on it, and not get sluggish. But I Love mine!   I still have my rotory too!
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
