Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Super Member davey g-force's Avatar
    Aug 2009
    1,225
    Question I'm Looking for a Cheap Paint Thickness Gauge
    What do you guys think of this one?
    http://www.ebay.com.au/itm/Portable-...item3a9ffe7753
    It's for a weekend warrior (me) who may only need it once or twice a year.
    Thanks in advance..
    Quote Originally Posted by Jason Rose
    Jul 2015
    The Mitten, USA
    Re: I'm Looking for a Cheap Paint Thickness Gauge
    subbed. Also interested
    Super Member Evan.J's Avatar
    Sep 2012
    Pittsburgh, PA
    4,915
    Search on eBay for CM8801FN
    Official Detailing Team Member of Air Force One
    Flex 3401 / Flex PE8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Davey, with that price listed, I thought, "you get what you pay for"
    that seems awfully cheap for such an instrument.
    Here's the one I bought. With nothing to compare it to, all I can say is that it seems to be working fine with decent accuracy. My roof is peeling on my daily driver, and the readings are pretty consistent on the clear coat portions vs the just-paint surfaces.
    google this: DBPower® CEM DT-156
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by davey g-force View Post
    I think that @$22.34 (USD) ea.,
    Your goal: Re: I'm Looking for a Cheap Paint Thickness Gauge...would definitely be met!!
    Super Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,686
    I think you need to be careful with that instrument, Davey. It has a display resolution of 0.02mm/1mil. That's a very poor resolution. On the other hand, the CM8801FN shown by Evan (I have this one too), has a display resolution of 1micron +/- 3%. That's a big difference in accuracy. 0.02mm is 20 microns!
    I purchased a cheap unit like the one you are looking at and did a comparison. These cheap ones with poor resolution/accuracy can lead to quite a number of erroneous readings.
    http://www.autogeekonline.net/forum/...ek-em2271.html
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
    Super Member mbkite's Avatar
    Apr 2009
    Sarcasm land
    838
    My take on paint correction with out a paint gauge..
    I have read so many show and shine posts that even when the paint readings are thin people polish them up any way.
    If you get the newest polishes with the most tech packed into that polish
    You will get great results.. I am thinking paint gauges are a thing of the past.
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Quote Originally Posted by mbkite View Post
    Not at all true... a ptg will allow you to more accurately asses the current condition and history of the paint. For instance, even if a vehicle consistently reads thin, it is no big deal if you're doing a basic correction... however, if the paint is averaging around 110 microns, and then you hit a spot that is consistently below 60 microns, you know you should be very cautious in that area because it has clearly been worked on (likely heavy sanding or similar)... or vice versa, if a car is continuously reading around 110 microns and then you come across a panel or a spot that is significantly higher, you can assume it was repaired/repainted.
    The more info you can get about a car before you work on it the better, so IMO, a paint gauge is a must have for a professional. Is it something that will make or break you? No... but if you're making good money correcting paint, it is a tool that is worth having.
    I did a review on an inexpensive gauge a while ago... I used it for a couple years and it did just fine, though I have upgraded to a higher end brand since then.
    http://www.autogeekonline.net/forum/...-everyone.html
    Just my thoughts
    Retired Professional Detailer
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Quote Originally Posted by zmcgovern45 View Post
    Just my thoughts
    I would not start compounding a car without some readings.
  10. #10
    Aug 2009
    1,225
    Thanks for the replies everyone.
    I checked out the CM8801FN and the DBPower® CEM DT-156 and I can get them here for $175 and $149 respectively. They look like good tools and I can see the value in them.
    However, for someone that will hardly use it, and has the option to borrow one, I can't justify spending that much.
    So that cheap one in my OP is no good at all? I mean, will it give me a rough idea of which sections of paint are thin and which aren't?
  1. Paint Thickness Gauge Quality vs Cheap Ebay
    By asap2stacks in forum Auto Detailing 101
    Last Post: 08-21-2017, 11:04 AM
  2. Replies: 8
    Last Post: 02-29-2016, 10:54 PM
  3. How to use a Paint Thickness Gauge (PTG)
    By hernandez.art13 in forum Auto Detailing 101
    Last Post: 07-18-2013, 10:45 AM
  4. How may of you own a Paint Thickness Gauge
    By Theostoubos in forum Auto Detailing Tools and Accessories
    Last Post: 05-11-2012, 02:11 PM
