Quote:
Originally Posted by turbos17 Bold statement or not I am right as I have used both and their WAS no difference in pad rotation, correction time, etc. I am sure others will chime in "Asphalt Rocket"  |
This "Asphalt Rocket"
ASPHALT ROCKET
Posts: 2,202 Re: Taping before polishing...
Quote:ASPHALT ROCKET
Stick with 5.5 foam pads on your da, wool really doesn't work well with your da, unless you step up to the surbuff wool pads.
If you are going the rotary route I use the 3M Superbuff III wool pads, kompressor pads and some lc pads. The wool is 9 inch I believe and the foam pads are 6.5 and 5.5.
If you need anything more than an orange pad use wool, it is easier to use, cuts/levels the paint better and in the ebd the finish will look better if you cut with a foam pad to start with.
