» Official Detail Fest 2010 Information Thread!! | |  | |
08-09-2009, 12:50 AM
#1 | | Senior Member
| Husky power washer&foam nozzle/lance at Home Depot
Hi has anyone had any experience with the Husky h1600 power washer from Home Depot?
It is a low end unit that I was considering to use for only detailing my cars. My thought was to get an inexpensive power washer so I could than get one of those crazy foam canons from AG. Isn't that putting the cart be- for the horse LOL.
Well to my surprise when I went to my local Home Depot I discovered that this low end 1400 psi unit came with as a no cost bonus a "power foam high pressure foaming nozzle with lance". The price of the Husky was $99.00. I viewed a video on utube and it seemed to be throwing some nice foam.
Any thoughts from the forum would be appreciated.
Thanks
Stu
__________________
[SIGPIC][/SIGPIC]“"IMPECCABILITY begins with a single act
that has to be DELIBERATE, PRECISE and SUSTAINED.
If that act is repeated long enough one acquires a sense of
UNBENDING INTENT which can be applied to ANYTHING else.
If that is accomplished the road is clear.
One thing will lead to another until the warrior realizes his full potential."” . . . . Don Juan Matus MAY THE SHINE BE WITH YOU |
08-09-2009, 04:51 AM
#2 | | Moderator
| Re: Husky power washer&foam nozzle/lance at Home Depot
I see alot getting the Karcher units in similar power and price, so this should work well too.
08-12-2009, 11:11 AM
#3 | | Senior Member
Do you have a link for this?
Usually the optional detergent foamer is mediocre at best, and runs out of soap quite quickly. I bought the Karcher Detergent Foamer for my Karcher Pressure Washer because it was fairly cheap and Autogeek wasn't carrying the Foam Cannon HP Kit yet. I used it a couple of times and now it just sits on the ground in my garage.
Anyways, can you give us a link before I make any judgment? It would help out.
__________________
08 Subaru WRX
08-12-2009, 02:25 PM
#4 | | Senior Member
| Re: Husky power washer&foam nozzle/lance at Home Depot Quote:
Anyways, can you give us a link before I make any judgment? It would help out. | Hi Emile,
Thanks for the info. I would be the first to say that this is probably not going to be on the same level as the foam canon. Having never owned a pressure washer and wanting a foam canon to get as hands free of a car wash as posihttp://huskypowerwasher.com/accessoriesmovie.phpble I felt it was worth a try as the Husky will only be used for car washing. To bad AG didn't offer a pressure washer to go along with the foam canon I would have bought that pkg. in a heart beat. Anyway here is a link to a video on utube demonstrating the high pressure foam nozzle and lance for the h1600 pressure washer. Husky Power washer
Let me know what you think as I have not used it yet.
__________________
08-12-2009, 03:58 PM
#5 | | Senior Member
Originally Posted by A4 1.8tqm While we're off topic about cheap power washers... Don't buy a Husky, all three of the Husky's my friends dad bought broke down with just a few uses. You think he'd learn huh?  | I would recommend getting a different brand, they have a bad rep for low build quality from reviews I've read, and the units I've seen in action have a 100% failure rate.
__________________
As of Oct, 20 2009 I have quit smoking cigarettes, cold turkey. After more than a decade of smoking at least a pack a day... 5 months down! |
08-12-2009, 05:52 PM
#6 | | Senior Member
Originally Posted by A4 1.8tqm I would recommend getting a different brand, they have a bad rep for low build quality from reviews I've read, and the units I've seen in action have a 100% failure rate. |
To each his own. We just took care of ours in Tampa, it was used for 4 years all day every day and did great. It was replaced only when someone wasnt paying attention and backed the trailer into it, bending an output pipe for the water.
__________________
Due to popular demand, I have changed my signature, Menzerna is no longer contraband on the forums, welcome to the AG family |
08-12-2009, 08:22 PM
#7 | | Senior Member
So... after advising against a product that I haven't personally had bad experiences with, I went and borrowed so called "broken power washer". Seems to me that it was more user error over faulty machine (at least his newest one). The machine needs to be tested (as stated on the power cord) ...simple, and you need to be sure that your hose is not full of air before attached and prime the pump with water before turning on (obvious?).
It works fine! I bet I know why his previous machines had "broke down"  . I apologize for giving advice based on others experiences. Plus he gave me the "faulty power washer", SCORE!
__________________
08-12-2009, 09:13 PM
#8 | | Senior Member
Hey thanks for the retraction. As I didn't take it out of the box yet I was all ready to return it to H D for a refund. Now I think I will at least give it a test run
__________________
08-12-2009, 09:29 PM
#9 | | Senior Member
That foamer nozzle doesn't look bad at all. I'm assuming you use the power washer's built-in detergent nozzle?
Either way, you can't do a touch-less car wash with a pressure washer....unless you get some really high-power gas washer then maybe. If it makes you feel any better, I bought my pressure washer only for car washes and it was worth every penny.
__________________
08 Subaru WRX
08-12-2009, 10:16 PM
#10 | | Senior Member
Originally Posted by Emile That foamer nozzle doesn't look bad at all. I'm assuming you use the power washer's built-in detergent nozzle?
Either way, you can't do a touch-less car wash with a pressure washer....unless you get some really high-power gas washer then maybe. If it makes you feel any better, I bought my pressure washer only for car washes and it was worth every penny. | Hi Emile and thanks for the feedback. The way I look at it my Porsche never gets no more dirty than a little light garage dust and the Escalade doesn't get much more dirty than that. My feeling was that I could foam up the car and than rinse it off with the pw and than use the garden hose in a sheeting manner and blot dry with my waffle weave towels and a QD if needed. I felt that for the price it was worth a shot. Had I already owned a pw than the foam canon would have been a no brainer. i will post some pics when I use it for the first time.
Stu
Oh by the way what part of NJ are you in? I am down on the NJ shore.
__________________
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
