» Official Detail Fest 2010 Information Thread!! | |  | |
06-27-2009, 03:00 PM
#1 | | Senior Member
| Which edge pad is comparable to LC orange
I just switched to the EDGE 2k and see they only have 5 foam pads. Is one similar to the LC orange for med cut? I know the yellow EDGE is for med cut but it leaves considerable marring itself, or should I just go to wool at that point?
Thanks,
Chris
06-29-2009, 06:25 PM
#2 | | Senior Member
| Re: Which edge pad is comparable to LC orange
Well they did have an orange pad back in the day. I believe the new green pad with softer foam is the equivalent to the LC orange.
__________________
Due to popular demand, I have changed my signature, Menzerna is no longer contraband on the forums, welcome to the AG family |
06-29-2009, 08:13 PM
#3 | | Senior Member
They actually have 7 edge pads. Black,Yellow,Orange,Green,Blue,White and Red. Just so you know But going to a wool pad isn't a bad idea either. Good luck.
06-29-2009, 08:17 PM
#4 | | Senior Member
| Re: Which edge pad is comparable to LC orange Quote:
Originally Posted by integritydetail I just switched to the EDGE 2k and see they only have 5 foam pads. Is one similar to the LC orange for med cut? I know the yellow EDGE is for med cut but it leaves considerable marring itself, or should I just go to wool at that point?
Thanks,
Chris | Wool pads are good, but what are you polishing with? Generally, I have never seen wool used on the PC. Rotary and now FLEX work with wool Quote:
Originally Posted by Buddy They actually have 7 edge pads. Black,Yellow,Orange,Green,Blue,White and Red. Just so you know But going to a wool pad isn't a bad idea either. Good luck. |
__________________
06-29-2009, 08:34 PM
#5 | | Senior Member
Originally Posted by ryandamartini Wool pads are good, but what are you polishing with? Generally, I have never seen wool used on the PC. Rotary and now FLEX work with wool | I'm using a Makita 9227C. Now is a very good time to introduce yourself to the wool pads. I should have done it alot sooner than I did. I created alot more work for myself by not doing so. If you get a quality wool pad like 3M for example. You won't believe your eye's. The correction is like night and day. Your confidence level jumps up a notch because you're not fighting yourself with foam when you need wool.
06-29-2009, 10:25 PM
#6 | | Senior Member
Originally Posted by Buddy I'm using a Makita 9227C. Now is a very good time to introduce yourself to the wool pads. I should have done it alot sooner than I did. I created alot more work for myself by not doing so. If you get a quality wool pad like 3M for example. You won't believe your eye's. The correction is like night and day. Your confidence level jumps up a notch because you're not fighting yourself with foam when you need wool. |
Hmm if you could send me a pm detailing when you personally use wool pads and what cuts, I would appreciate it very much!
__________________
06-29-2009, 10:38 PM
#7 | | Senior Member
I have a PC 7428 rotary, Flex 3401 VRG, PC 7424 d/a, and a cyclo. all have edge adapters. I am using the rotary for 2 and 3 step corrections, flex to finish and on one steps. I am not at all intimidated by the rotory any more, probably no reason to fear wool either.
06-29-2009, 11:23 PM
#8 | | Senior Member
Originally Posted by integritydetail I have a PC 7428 rotary, Flex 3401 VRG, PC 7424 d/a, and a cyclo. all have edge adapters. I am using the rotary for 2 and 3 step corrections, flex to finish and on one steps. I am not at all intimidated by the rotory any more, probably no reason to fear wool either. | Very good deduction. You have just taken another step of many... |
06-29-2009, 11:29 PM
#9 | | Senior Member
Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
With Edge 2K I use the green pad where I'd use LC orange.
06-30-2009, 10:04 PM
#10 | | Senior Member
Thanks guys, I'll let you know when I burn thru, haha. Do any of you use the yellow E2K?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » March 2010 | | S | M | T | W | T | F | S | | 28 |
| | 28 |
| 1 | 2 | 3 | » Car Care Brands | | | |
