finally got a chance to try out my canopy
for those that dont know its a First UP 10X10 pop up canopy
instructions say you need 2 people to set it up but i found it easy enough to set it up by myself as long as you can 1 of the legs to catch a lip somewhere and keep from moving and by pulling and pushing in key place. but totally doable by yourself, even the fabric top as before you extend the legs its only about 4 feet or so off the ground. just stand in the middle and through the fabric over the center and work your way out
it has decent coverage but i wish it was about 5feet longer
there was still a great deal of sun hitting MY car and i will just guess it will be worse for those with full size cars and suvs
most likely i will still continue to use it despite its full car coverage, some coverage is still better than none!
will also try next time to see if moving it around different ways will get me better coverage and still need to order the walls to see if that helps as well
will be great for camping though especially with the screen walls
so it will def get its share of use either way
some pics to show coverage
also got to play with 2 of my bday presents
the pressure was bought by my gf as per her instructions, lol
and i bought the foam lance
